Author Topic: starter drains battery hard  (Read 1764 times)
bollingball
Re: starter drains battery hard
« Reply #25 on: June 15, 2013, 07:56:32 AM »
trueblue +10 You just need to clean up the starter just new brushes will not do. Forget the battery ::) If you are not up to it where you live will have a ton of starter rebuild shops they will clean it up check bearing or bushing and have it back in a day or two. Then you can be doing other things. But take it off for them. Hit the yellow pages. Now if you want to do it. On larger starters I use a hacksaw blade trimmed down on a bench grinder. These are small and a sharp pick works good to clean out the grooves a big rubber eraser works to shine everything up and some brake clean to wash it off. Then you have to see how much it wobbles in the old end caps. Then check it electrically The shop has everything and can do it faster.
EDIT Looks like you posted while I was typing.
Ken
« Last Edit: June 15, 2013, 08:00:50 AM by bollingball »
Offline nevernoluck
  • Nope I don't have a clue
« Reply #26 on: June 15, 2013, 08:18:27 AM »
+1 on the big eraser trick
Offline trueblue
« Reply #27 on: June 16, 2013, 03:24:11 AM »
Thanks true blue that's the kind of info I was looking for. Probably didn't clean it well. Unfortunately I don't have the tools to do that, so I may be looking for a rebuild of some kind. May get an oem solenoid too to be safe. Anyone know of an aftermarket starter or someone who does a full rebuild? For the time being ill get my leg workout ;)
No worries mate, if I was a little closer I would do it for you for a 6 pack, but by the time you shipped it here and back it would be cheaper for you to buy a brand spanker.  If you don't have the gear to do it find a good auto leccy locally.  I'm sure someone nearby should be able to do it for you fairly cheaply ;D.
1979 CB650Z
