Author Topic: Head Light Ear Shims  (Read 700 times)
Offline Powderman
« on: June 14, 2013, 08:06:24 PM »
I have a set of the cast aluminum headlight brackets with the plastic shims for different size forks. I don't seem to have any for 37mm forks. Does anyone here have any or know where I might be able to find some?
Offline bikerbart
Re: Head Light Ear Shims
« Reply #1 on: June 14, 2013, 10:28:09 PM »
Just make your own, thats what I would do, be creative
« Reply #2 on: June 14, 2013, 11:15:14 PM »
I think what he means is someone likely has a set.. That size is not. Used every day
Offline Powderman
« Reply #3 on: June 15, 2013, 08:28:07 AM »
754 is correct. I don't know if the set I got is missing shims for 37mm, or if it didn't come with them due to the odd ball size. I have I think 3 sets of shims, of them 2 are too small and one too big. I can't think of how to make a 1mm thick shim that won't look tacky or Mickey Moused. I'm open to suggestions.
« Reply #4 on: June 15, 2013, 08:31:02 AM »
Easy to make on a lathe, but leave a small lip , helps square it up.. Or use .040 shim stock
Offline Old Scrambler
« Reply #5 on: June 15, 2013, 01:29:08 PM »
I'm guessing you have GL fork tubes...............for that thickness I would cut up an old inner-tube for the shim. The benefit is no direct metal contact and you don't have to over-snug the ears to keep them in place.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Powderman
« Reply #6 on: June 15, 2013, 07:28:12 PM »
Scrambler, they are CB600f1 forks. I was able to cut a soda can and wrap the tube and then some high temp masking tape to secure it and it works. I hate mickey mousing it but it will do for headlight brackets.
754, how would you make them on the lathe? Make a tube then just split one side?
Offline tomkimberly
« Reply #7 on: June 16, 2013, 01:07:57 AM »
Tape works..  Just sayin....
Tom
