Author Topic: Tews' 605 build, On the road! 5/4!  (Read 81085 times)
Offline Tews19
  • I am no
Re: Tews' build GSXR front end, 10/2 600cc UH OH!
« Reply #225 on: October 03, 2013, 01:29:44 PM »
More goodies picked up...
I've run into an issue for the rear shocks.... I ordered ones a tad bigger than stock yet it still seems low... hmm
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
« Reply #226 on: October 03, 2013, 02:59:47 PM »
Quick mock up... I think I will have to make a custom seat....
Should I angle the shocks? Some insight as to which stance to go with is much appreciated...
« Reply #227 on: October 03, 2013, 04:32:35 PM »
Def angled, the second pic looks about right.
Offline sixthwisconsin
  • With an 1855 Springfield, I'm a
« Reply #228 on: October 03, 2013, 05:08:01 PM »
Are you giving any thought to running a modern rear wheel as well? I love the Benelli tanks... You have a great build going!
Offline Tews19
  • I am no
« Reply #229 on: October 03, 2013, 05:38:23 PM »
I already have an 18" aluminum rim and new spokes... I need to lace it up and rebuild the hub
Offline Heffe
« Reply #230 on: October 07, 2013, 03:25:05 PM »
Great build so far...subscribed!
New to me 1977 cb550
1998 Triumph sprint
1977 cb750
Offline brandEn
« Reply #231 on: October 07, 2013, 03:26:43 PM »
+1
Offline rb550four
« Reply #232 on: October 07, 2013, 06:19:41 PM »
Looking good! I like a longer lay down shock set up,looks and works better than shocks straight up, of course we would all like to try a mono shock set-up, but the lay downs look good too.
   Before you weld up , don't forget that you have no engine weight ,height may be effected if you plan it on an empty cradle.
« Last Edit: October 07, 2013, 06:24:14 PM by rb550four »
Offline Tews19
  • I am no
« Reply #233 on: October 07, 2013, 08:23:08 PM »
Great insight RB... Should I install the engine prior to welding?
Offline calj737
  • I refuse...
« Reply #234 on: October 08, 2013, 05:24:43 AM »
Tews - slanted/straight in shock? Slanted looks better on your build. Remember you are moving the rider weight between the shock and the tank only and removing the rear passenger. Supporting only the rider now, the shock boss can move forward.
Height - bear in mind the the temper the angle, the shorter the shock will lay. Can you/did you adjust the damping on huge shock to "extend" it? May make a bit of difference in rider height. Also, final clearance will be affected by tire height.
I don't to inktxhe engine weight will play enough part in the clearance on the rear hoop to worry about (at least it didn't on my bike, and I removed the entire back half also for a custom hoop).
(Personally, I would decrease the slant you show in the picture as it reduces the overall effectiveness oft e shock in that orientation. Maybe something between 65-75 degrees).
Bike looks very killer!
Offline jojo
« Reply #235 on: October 22, 2013, 02:22:31 PM »
any updates?
Offline edhaeuser
« Reply #236 on: October 31, 2013, 10:56:58 AM »
Nice stuff Tews!  Keep it coming.
Offline Tews19
  • I am no
« Reply #237 on: October 31, 2013, 12:27:50 PM »
Sorry no updates to give. Time has been limited..... We did find out that we are expecting so this build needs to be done before summer.
Offline edwardmorris
  • Youngish
« Reply #238 on: October 31, 2013, 01:44:57 PM »
Congratulations!
« Reply #239 on: October 31, 2013, 05:51:22 PM »
Congrats Tews.   I am expecting too.....a K3 race bike next week!
Offline cheftuskey121
  • Super Newbie
« Reply #240 on: October 31, 2013, 05:52:06 PM »
Congrats man! I bet that's an awesome feeling :D
Offline SF
  • I burn gas very well
« Reply #241 on: October 31, 2013, 07:23:03 PM »
Congratulations! That would be a good idea if you finished it!!
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Tews19
  • I am no
« Reply #242 on: October 31, 2013, 08:59:11 PM »
Thanks everyone.... I do have some free time in the morning.. I could scrub the engine down and take off the head and cylinders.... My only concern is how do I store it if I am not getting the work done right away? Would it be safe to store in my basement back room with a dehumidifier that runs constantly?
« Reply #243 on: October 31, 2013, 09:13:47 PM »
Sure.  It's mostly aluminum, what's your concern? Just don't leave em sittin in the snow all winter!
Offline Tews19
  • I am no
« Reply #244 on: November 01, 2013, 07:04:47 AM »
Oh no, I meant that the engine will have the top end off and in the basement where the dehumidifier constantly runs. I don't want to have the engine get rust on it.
« Reply #245 on: November 01, 2013, 07:10:23 AM »
I'd spray it with WD and cover with a towel. No prob.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #246 on: November 01, 2013, 01:15:25 PM »
Congratulations, your going to need a bigger boat house
Offline Tews19
  • I am no
« Reply #247 on: November 11, 2013, 11:33:28 AM »
Progress. Removed the head and cylinders.... I need to clean them up and pack to send Mreick... Engine was clean IMO. Hopefully other will chime in.
Offline Tews19
  • I am no
« Reply #248 on: November 11, 2013, 11:41:21 AM »
I also tried my hand at making my own seat... I sprayed with loctite adhesive yet it is not that sticky.
Offline Mcwilliams570
Re: Tews' build GSXR front end, 11/11 engine disassemble
« Reply #249 on: November 11, 2013, 02:26:53 PM »
Engine looks good I used gorilla glue for the foam on my last project. Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
