Author Topic: If you need pistons/rings for your CB500 or CB550...  (Read 6927 times)
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« on: May 17, 2005, 11:43:24 am »
Check out the kits sold by www.classiccycleparts.com
They have a 555cc overbore kit for the CB500 which is a 3.0mm overbore for the 500.  It also works out to be a 0.50mm overbore for the CB550, which is what I'm using it on.  They also sell a 605cc big bore kit which comes with sleeves.  It would be a 2.5mm overbore on the 550, which I presume would be ok if you want an extra 50cc's.
Anyway - the reason I'm posting this is because I just received my 555cc kit today.  I had a look inside - small box with an MC label on it from Los Angeles.  Imported from Japan.  Nothing special about that.  Opening that, I found 8 white boxes - 4 pistons and 4 sets of rings.  Again, nothing special.
So, I naturally opened up a piston box and started looking at it.  Chundy had a peek too, and noticed 'ART' cast on the inside of the piston  ;D
These are ART pistons, which means they're good!  ART made/makes pistons for Honda.  So, in a nutshell, these are ART piston kits which include:
4 59mm pistons
4 sets of piston rings
4 wrist pins
8 clips
1 head gasket
The price for these kits is US$100 + shipping (for the 555cc kit).  They raised the price $20 the day I bought (after).  I actually paid $101 US all in, shipped to Canada.
This is obviously a great deal, considering Honda wants $30+ per ring set, $30 per piston, $10 per wrist pin etc...
So, if you need pistons, I would not hesitate to order the 555cc kit from these guys.  Can't speak to the 605cc kit, but I know someone out there has one - have a peek inside the piston to see if ART is cast on the wall.
I'm off to my mechanic for a bore and reassembly  ;D ;D
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline neckyzips
Re: If you need pistons/rings for your CB500 or CB550...
« Reply #1 on: May 17, 2005, 03:41:15 pm »
ok, ok, ok, tim...
nope mine dont have art, they do have "HANDST"  and a star with "sk" scribed inside, and "600cc" they are pretty none the less. i am sure someone could use them...
oh, and guys check out this:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4549668404&ssPageName=ADME:B:BODO:MT:1
nos cb500 pistions and rings looks like they are 1mm over. i happen to have it on good athority that he will take 50 bucks for them.
