Author Topic: NO LIGHTS!!!  (Read 1061 times)
Offline matchstikman
  • ask the toecutter! he knows who I am!
NO LIGHTS!!!
« on: June 16, 2013, 07:54:24 AM »
I ride a 76' 750f and ran into a short. the 7a headlight fuse won't hold which means no tail light, (except the brake light), headlight, speedo or tach light. I have a plan to avoid getting in over my head on the wiring. Wondering if this quick fix is going to last. ----run wire from batt + to 15a fuse to toggle to headlight. new ground for headlight. between toggle and headlight splice in speedo, tack, and tail light.---
« Last Edit: June 16, 2013, 12:28:51 PM by cptChavez750 »
Stone (1974) Greatest biker movie ever made!
Offline MoMo
  • Ride like you're invisible
Re: NO LIGHTS!!!
« Reply #1 on: June 16, 2013, 01:30:11 PM »
As long as you use a properly rated switch with the correct gauge wire it should work, but why a 15a fuse when the original is 7a?
Re: NO LIGHTS!!!
« Reply #2 on: June 16, 2013, 01:42:53 PM »
I have a box of 15's sitting around. I guess I should pickup a 7a. Yes, I think I'll do that. Thanks for the response momo.
