Author Topic: Starter motor question  (Read 667 times)
Offline acollin
« on: June 20, 2013, 04:49:03 PM »
1973 Cb 750
Starter motor fires up but does not engage.
What should my friend expect to see and then repair when he starts to turn a wrench?
Thanks
Offline nccb
  • 1974 CB750 Four
Re: Starter motor question
« Reply #1 on: June 20, 2013, 06:32:39 PM »
possibly starter clutch.  take the alternator cover off and have a look, try and lean the bike to the right when you do as oil will come out.  IDK if you have a book available or not but use the custom search on this forum for starter clutch and I am sure a lot will turn up, many threads started over this including one from me.
« Reply #2 on: June 20, 2013, 08:01:44 PM »
If the starter motor sounds like it is just spinning freely, the alternator rotor may be spinning on the crankshaft due to a loose bolt; this happened to me shortly after I bought my bike. Like nccb said, pull off the alternator cover, as all of the starter gear-train is under it. The shifter cover will need to be removed first.
