Author Topic: oil leak stator cover 78 cb550  (Read 1422 times)
Offline uksparky
  • Track days
« on: June 21, 2013, 08:05:05 AM »
Thought i was finished with oil leaks   >:(  riding the other day i noticed some oil on my gear lever rubber and my boot..not much...So i have a oil leak from the bottom of my stator cover, small drip...is there a oil plug in the bottom..or am i looking at the oil seal behind the stator (crank seal)
Present bike 1982 900C Custom
Offline ngonerogwu
  • cb350/550
Re: oil leak stator cover 78 cb550
« Reply #1 on: June 21, 2013, 08:06:52 AM »
You sure it's not the oil pump or shifter seal? I think that's more common on our bikes.
Offline aggiepike
    • Compare and Save on Electric Rates in TX
« Reply #2 on: June 21, 2013, 08:18:34 AM »
let your bike sit for a little after riding and then look on the under side of your stator to see if the oil is concentrating at the bottom of the stator on the outside of the cover. If so, check to make sure the bolts on your stator cover are tight. I pulled mine a while back and had a leak. I tightened mine up and no more leak.
If you do have to pull it and replace the gasket you can still get those from a Honda dealer and they are not too pricey.
K1 CB750 (836)
Offline uksparky
  • Track days
« Reply #3 on: June 21, 2013, 08:26:14 AM »
I just replaced the shifter/oil pumps seals....there should be no oil behind the stator cover right?? the 750s do have oil in there ....bolts tight...waiting for info on the seal......oil gallery plug...thats if it has one
Offline uksparky
  • Track days
« Reply #4 on: June 21, 2013, 11:23:10 AM »
Well curoisty got the better of me ..i just had to take a look, removed the stator cover, saved the gasket...rested the cover on a block of wood and there was the small leak coming from a plunger at the bottom of the crankcase..pulled it out and there is a round oil seal that was kinda old, pulled it off and found a new one in my box of O ring seals. problem solved....crank seal ok..one of the POs spit the cases at some time,..signs of sealant
