The SOHC/4 World Tour is in under way.
I have been very happy with Progressive Springs (heavy duty) on my K4 - have them front/rear. cheersAndy
I went a little different direction than most here. I went with Sonic strait rate springs up front and a set of Hagons on the rear.
I've enjoyed using stacked up flat washers as spacers w/ much success.
Hmm, not hearing good about the Progressives here,
Quote from: Tripps on June 25, 2013, 07:35:16 PMHmm, not hearing good about the Progressives here, Not from me I really like the front progressives on my K4 - and have them on the rear as well. Used them for the last 40,000 miles and couldnt be happier. So far I have found the straight springs to be a little stiffer (same 10w oil) but dont have enough mileage on them to compare. Old forks are old forks though
Not sure I understand, do you mean you have Progressive non-progressive shocks? (straight springs)
