Author Topic: Doubling-up oil seals on forks?  (Read 2354 times)
Offline Bru-tom
« on: June 25, 2013, 03:10:18 PM »
Hey fellas,
I know that one should use a double what what oil seal on the forks as it not merely an oil seal keeping oil in, its also exposed to linear movements.
I cannot for the life of me source the correct seals locally (in SA). Could i not perhaps use 2 x 5mm thickness ones therefor getting the double what what that is required for such an application?
Is it something i could consider?
Many thanks ;)
Offline Powderman
Re: Doubling-up oil seals on forks?
« Reply #1 on: June 25, 2013, 03:14:41 PM »
Some bikes came with double seals and then were changed to a single wide seal. They were not necessarily the same thickness. I suppose 2 seals measuring the same width as the stock one would work in a pinch.
Offline Bru-tom
« Reply #2 on: June 25, 2013, 03:21:56 PM »
thanks mate! i had a look at the seals that came out my forks. there are two lips that stick out on ether side. one that is singular and the other with tow rings. i cant find a pic with two but here is one i found with three (3) for reference purposes.
If you look closely, you can see three small little lips on the one side of the seal. That's what i am referring to. the honda seal has two and the ones i can get have one. so i thought id double up, causing me to have two essentially too.
PS, its called double lip oil seals...
« Last Edit: June 25, 2013, 03:54:58 PM by Bru-tom »
Offline Powderman
« Reply #3 on: June 25, 2013, 05:38:28 PM »
What is the seal in the pic for? What bike is it going on? What physically sits on top of the seal. My forks have a retaining snap ring and dust boot on top so I couldn't stack 2 seals if I wanted to.
« Reply #4 on: June 25, 2013, 10:34:23 PM »
I'm sure Dave Silver will post to SA
Offline Bru-tom
« Reply #5 on: June 26, 2013, 01:38:07 AM »
thanks for the replies guys.
the seal is going in the top of my forks and there is a snap ring retainer. the original thicknesss is.....
il order two ;)
Offline Powderman
« Reply #6 on: June 26, 2013, 08:05:47 AM »
Unless you find seals half the thickness of stock ones stacking 2 will not fit.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=smam7l29n9hva4097ud0k1k304&/topic,60973.0.html
« Reply #7 on: June 26, 2013, 09:53:46 AM »
i alvays put a nylon spacer in..there are some ekstra space..with the new type sealing(or some of them)..so i use one ,,with dubbel lips..and a spacer before the snap ring..it work fine on my cb 550 and  cb500t
« Last Edit: June 26, 2013, 09:59:09 AM by strynboen »
i hate all this v-w.... vords
Offline 01Thomas
« Reply #8 on: June 26, 2013, 01:38:41 PM »
I went to Honda Pinetown (in Durban, SA) and ordered Honda P/N 91255-KBH-003 from them. This is a double-lip seal with one lip acting as a wiper. Many seals for linear movement have wipers but what makes this one different is that the wiper also has a garter-spring (as does the regular sealing lip).
I fitted them to my K1 about 10 000 km ago and haven't had any problems - but it must be said that the K1 has gaiters on it's forks and they do keep the muck off.
On my Moto Guzzis I fit double-lip seals from the local bearing agent - until I reforked my SP1000 with the forks from a 2005 Yammie R1 !
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline Bru-tom
« Reply #9 on: June 26, 2013, 04:58:45 PM »
Thanks guys, my surname is Thomas, maybe we related hahaha, im from East London and out honda dealer is rubbish.
I have double checked and thats the same PN as the ones i require. i think i may contact your dealer in that case. Thanks for the heads up.
I found that the doubling-up of the seals will not work, the smallest thickness available is 7mm.
