Author Topic: what do you use in your tank cleaner?  (Read 704 times)
Offline bert96
  • past ride
« on: June 26, 2013, 07:01:23 AM »
I've just bought a little tank cleaner (just like the link) and i would like to know what you are using guys to clean your parts? is simple green strong enough?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390580831883&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
Thanks
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline bert96
  • past ride
Re: what do you use in your tank cleaner?
« Reply #1 on: June 27, 2013, 03:12:48 AM »
Anyone?
Offline rb550four
« Reply #2 on: July 06, 2013, 08:02:21 PM »
I use Kerosene , I don't use the electric pump or smoke near it.
I was recently considering sealing off the pump hole just to keep all the fumes in check.
I also add carb cleaner, brake clean ( and everything else that cleans) into the mix every time I clean something. So right now it's cleaning parts very well, probably toxic as hell, and a real health risk....But I figure that I'll be effected by all the aluminum oxides and have Alzhiemer's long before the cancer can kill me.
I really hate dirty parts.
I'm sure someone here uses something safer.
Offline bert96
  • past ride
« Reply #3 on: July 10, 2013, 04:05:05 PM »
Thanks for the reply!
 You are the only one who clean their parts!
Bert
« Reply #4 on: July 10, 2013, 06:25:55 PM »
For anything with oil or grease, kerosene is the best. I have tried all kind of degreasers, Kero kicks all their asses. If you want a small amount get some Lamp Oil, it is just Kero.
« Reply #5 on: July 11, 2013, 02:50:11 AM »
So, is a tank cleaner a parts cleaner or an ultrasonic cleaner?
Purple (biodegradeable) Simple Green from Home Depot does a nice job on aluminum and is gentler on aluminum but is more expensive.
Kerosene is a very good degreaser.
Offline bert96
  • past ride
« Reply #6 on: July 13, 2013, 07:38:56 AM »
This is what i bought finally.
Bert
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #7 on: July 13, 2013, 11:45:40 AM »
If you own a shop in California you can only use a biodegradable water soap base products. Which isn't so bad, The degreaseres out now are fairly good.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
