Author Topic: 1972 or 1973 CB750 ??  (Read 3894 times)
Offline dooger54
« on: June 27, 2013, 06:29:24 AM »
Hope someone can help identify year of this bike.
Looks to me like the frame number indicates a 1972, but other indicators note a 1973.  I believe the olive green color was only available in 1973?  The engine ID tag is almost worn off, but it looks like the first two numbers are 22.  That would indicate a 1972?
Bike has been in storage for 15 years, has 8700 miles .  This is actual according to owner.  Condition of everything would agree with that.
Perplexed in Illinois.
Sent from my iPad using Tapatalk HD
Offline KC_Northstar
Re: 1972 or 1973 CB750 ??
« Reply #1 on: June 27, 2013, 06:39:28 AM »
Engine number starting with 22 indicates a K3.   Frame number is K2.  side cover emblems appear to be K3 or later.
Does it have the extra push button switch on the left control?  It was a button that canceled the turn signal beeper
and was only on a K2.
  KC
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline acollin
« Reply #2 on: June 27, 2013, 06:42:44 AM »
It looks like 1973 paint on a 1972 bike. There are a few oddities that separate the 72 from the 73.
For example: are there one or two buttons on the left hand handle bar switches? 2 buttons are from 1972-- one button is most liked 1973 or later.
Tough to see any detail in your pictures, but there a few parts differences in the two models.
« Reply #3 on: June 27, 2013, 06:44:22 AM »
Also, How many fuses does it have.   K2 had one fuse.  K3 had the fuse box with multiple circuits and fuses.
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline harisuluv
« Reply #4 on: June 27, 2013, 06:44:38 AM »
The plate is 72, didn't roll over to the next year til sept.
Tank decal is definitely post 72 giveaway but I have seen lots of changes in that year and some 72 came out with some 73 styling. Ie brake caliper arm and bracket is even listed on microfiche as both older and newer style cause a switch was made.
That said, looks like you have some swapping of parts.  Chain guide, fork ears, maybe unicorn, tank and side covers look like a repaint to me.
Offline acollin
« Reply #5 on: June 27, 2013, 06:47:01 AM »
The seat looks like a 1972-- are the gauges structured in a rhino? Rhino dropped in 1973-- last year for rhino was 1972
« Reply #6 on: June 27, 2013, 07:34:38 AM »
I would have said the seat was a K1 (or cross-over K1/K2?) - the K2 seat was fatter with a different stitching pattern - like mine (which is a K2)
If you want to sell the seat Id be interested...used to have one just like it and really liked it.
Nice bike anyway
Andy
Offline dooger54
« Reply #7 on: June 27, 2013, 08:19:16 AM »
Here are pics of both sides.
I don't think the tank and covers are repainted.  I know what to look for on repainted and I would be pretty certain they are all originals.
Offline Johnie
« Reply #8 on: June 27, 2013, 08:29:25 AM »
Welcome to the forum. Here is a pic of my K3 for you to compare...build date 10/72, engine 221 all OEM. Keep in mind Honda started the change over in models each year in August / Sept. My K1 is actually titled as a 1970 because it was sold in 1970, but it is actually the K1 model which is the 1971. Click pic to enlarge it.
« Last Edit: June 27, 2013, 11:44:00 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline dooger54
« Reply #9 on: June 27, 2013, 08:51:54 AM »
Here are gauges.
Also, what kind of front forks are these?  Don't look like the standard ones.
Offline acollin
« Reply #10 on: June 27, 2013, 09:09:12 AM »
The left hand handle bar switch is not from a 1972 ( not two button) and since there is no"rhino" in your gauges picture, that set up is not from a 1972.
I did not mean to suggest that there was a repainting of tanks and side covers. I meant only to suggest the paint ( painted parts: tank and side covers)  was swapped onto a bike with 1972 ID numbers.
The bike is a blend-- probably a great ride, just a collection of parts from a few model years.
Offline dooger54
« Reply #11 on: June 27, 2013, 09:21:12 AM »
Just seems strange to me that someone would go to all the work of putting tanks, gauges, handles, etc etc from a 1973 on a 1972 frame. But if that's what happened, so be it!
Offline Tews19
  • I am no
« Reply #12 on: June 27, 2013, 09:21:20 AM »
Nice bike and welcome! It's a 73 . Eitherway enjoy and I can't believe I missed that if listed on CL.
1970 Honda CB750 survivor.
« Reply #13 on: June 27, 2013, 09:58:43 AM »
The head suggest 72. And earlier, but the first 73 had that head.. Old scrambler has one to compare numbers with.
Check the steering stop for damage, front end looks swapped.  Silver caliper was KO, and the birdbath master cyl cap is KO or at latest 71..
 I like the color, if you get it, you can take sidecover emblems off and change back to the script type..lok a lot nicer.
Offline Johnie
« Reply #14 on: June 27, 2013, 11:51:23 AM »
To be honest I never saw an engine tag worn off that bad? Seems questionable and a  bit fishy to me. Does he have a title? And can you turn the motor over with the kicker? If that is indeed a KO caliper on the front then that would explain different forks. The KO caliper will not work on K2 or K3 forks. If you are wanting to get that back to the OEM look you can still find the proper fork ears for it. Maybe you can get a little more info out of the owner. Feel free to ask any questions here. How much is he asking for it? Again...does he have a title with the frame number to match it?
« Last Edit: June 27, 2013, 11:54:17 AM by Johnie »
Oshkosh, WI  USA
« Reply #15 on: June 27, 2013, 02:55:39 PM »
That caliper will,fit 72 Fork, but would be black. Behind where the caliper mounts, is that ledge the same on both? Almost looks like mismatched legs..
Offline dooger54
« Reply #16 on: June 27, 2013, 07:38:32 PM »
Owner had to order duplicate title from IL DMV.  He lost original, bike has been in storage and forgotten about for 15 years.
Will wait and see what year title comes back with.  Doesn't really matter to me as long as I can get title
Don't really understand what you guys are saying about the front forks.  Sorry for the ignorance, but my first bike in 40 years.  Have been into classic cars instead.
Doug
