Author Topic: 350 4 Race Pistons  (Read 1506 times)
Offline bsa a65
350 4 Race Pistons
« on: June 28, 2013, 09:40:51 AM »
Hi, anybody know if there are high compression pistons available for a 350 4, standard 47mm bore , or an alternative that can be used.
Offline MondayLSR
Re: 350 4 Race Pistons
« Reply #1 on: August 11, 2013, 10:50:25 AM »
Been talking with a few companies trying to get a set made. No one but wiseco has a forging that small, and they require a few sets be made for custom orders. Only real option is going to be billet, which are pretty pricey ($1000-$2000)
I have spoken to arias, wiseco, diamond, and wossner. (The wossner rep used to work for je).
Online scottly
« Reply #2 on: August 11, 2013, 09:00:29 PM »
Several of the small Honda singles used 47mm pistons, such as the CT 70, and XR70s. Wiseco lists a piston for the 2001 XR 70 with 10.5:1 CR. It might be worth asking them for a blueprint of the piston to see if it might be used as an alternative. BTW, these pistons are not cheap: $104.38 each. There is also a ProX version, most likely cast, for $51.15 each.
