Author Topic: timing light  (Read 1453 times)
Offline cobra
timing light
« on: June 28, 2013, 11:44:53 AM »
can anyone recommend a timing light, for use on my cr750, I am using boyer bransden ignition system, I bought one a few weeks ago, thinking they were all the same, but on opening it, it states not suitable for motorcycles,
Offline turboguzzi
Re: timing light
« Reply #1 on: June 28, 2013, 12:18:28 PM »
maybe give it a try?
can do no harm
Offline MoMo
  • Ride like you're invisible
Re: timing light
« Reply #2 on: June 28, 2013, 12:51:52 PM »
can do no harm
agree,  the light reads the time of spark so I don't know why it wouldn't work on motorcycle....larry
Offline lordmoonpie
    • Moonpie
Re: timing light
« Reply #3 on: June 28, 2013, 03:05:12 PM »
Tony, you need to look for an older light without the stupid advance features that all the modern Gunson  types seem to have, just a plain old strobe with inductive pickup is best. Keep an eye out on eBay and try and get an older sun automotive one, it'll be cheaper, probably better put together and it'll work! Good luck :-)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline turboguzzi
Re: timing light
« Reply #4 on: June 29, 2013, 01:15:08 AM »
i use this one and now see that it has a "no motorcycles" warning too....  :o
http://www.drapertools.com/b2c/b2citmdsp.pgm?pp_skmno=52616&ipadd=#!prettyPhoto
maybe because so many new bike shave now the "coil on cap" thing and it will just not work with it
well, i can tell you it does work!
Re: timing light
« Reply #5 on: June 29, 2013, 10:04:29 PM »
I believe the issue with inductive pickup timing lights is due to the wasted spark system. Most inductive pick-ups are directional: there is an arrow that should point towards the spark-plug. One lead on each dual coil is the opposite polarity of "normal", so may not trigger the strobe unless the pick-up is reversed.
