Author Topic: CB550 Overheat and smoke after long ride  (Read 3993 times)
Offline felicious
« on: June 29, 2013, 05:22:56 PM »
I just got back from a 2h ride on PCH. It was a very hot day and the last 20-30 min. were mostly stop and go. At the last 2 stop lights I noticed some white smoke coming from my engine and the engine idled very roughly. I had a hard time keeping the engine running and stalled the bike twice.
I barely made it into my garage which is where I stopped and took this video. I felt like the smoke was coming from the area where the oil spilt(?). The smoke is less noticeable in the video but I could see it coming from the engine with my own eyes.
Honda CB550 smoking
The bike started again but died pretty quickly.
Honda CB550 dying
Does that look remotely normal too you?
I will try to start the bike again tomorrow to see if it still idles rough.
The next two things I have on my list is to swap out the spark plugs and to make an oil change but this list will be adjusted according to your guys's advice. :)
Thanks,
Felix
Offline toytuff
  • "watching the pinheads"
Re: CB550 Overheat and smoke after long ride
« Reply #1 on: June 29, 2013, 05:25:06 PM »
Lot of oil on the lower head that I can see. Interested in seeing the plugs.
tt
« Last Edit: June 29, 2013, 05:27:34 PM by toytuff »
Offline Bailgang
  • Scott
  • Indiana
« Reply #2 on: June 29, 2013, 05:45:21 PM »
Just curious but was the clutch slipping at all during the 2 hr ride? The reason I ask is that when I first got my 550 up and running years ago I took it out and let it go on a straight, I was new to bikes at that time and was using motor oil that had friction modifiers in it which I later found was a no-no for wet clutch bikes and this made the clutch slip like crazy as I wound it up and it too was smoking when I got home. In my case the slipping clutch combined with a full throttle blast pretty much toasted the oil and overheated the engine.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline felicious
« Reply #3 on: June 29, 2013, 06:17:51 PM »
Hmm possible, I had problems not stalling the bike. I also just checked the oil level and it looks like it might not have enough oil. I checked with the kickstand so I will repeat that with the bike upright. Do you fill it up where the oil stick goes? I'm going to check out where to fill up the oil.
Or should I just do the oil change tomorrow and see if that helps?
« Last Edit: June 29, 2013, 06:37:42 PM by felicious »
Offline toytuff
« Reply #4 on: June 29, 2013, 06:34:56 PM »
You really didn't mean that did you?
You better get a service Manual. Soon.
tt
Offline felicious
« Reply #5 on: June 29, 2013, 06:36:33 PM »
Yes I have it and the clymer manual too.
I'll look it up.
bollingball
« Reply #6 on: June 29, 2013, 06:54:08 PM »
If I were you I would NOT start the bike back up. You need to sit down with the service and operators manual. You need to get a good understanding of how you bike works before you do some serious damage. I'm not trying to beat you up just trying to save you some unneeded headache's
Ken
Offline felicious
« Reply #7 on: June 29, 2013, 07:27:18 PM »
Ken
Do you think it is an oil related problem?
« Reply #8 on: June 29, 2013, 07:53:01 PM »
We need more info:
What kind of oil is in it?
Does the bike have stock exhaust, air box, jets?
What do the plugs look like?  Lean or oil fouled?
Offline Tews19
  • I am no
« Reply #9 on: June 29, 2013, 09:34:41 PM »
Looks like one hell of an oil leak on the head gasket..... cam tensioner sounds rough.. Could be the engine and lack of oil.... Also, I noticed you keep the petcock on when not running....Always turn to off when not being used....
1970 Honda CB750 survivor.
Offline felicious
« Reply #10 on: June 29, 2013, 09:37:08 PM »
We need more info:
Oil is whatever the PO put in (that's why I want to do the oil change). Exhaust is stock.
Haven't touched any other parts yet.
Offline goldarrow
  • one day, i'll be an
« Reply #11 on: June 29, 2013, 10:09:59 PM »
If oil is what the PO put in, then this is the time to do your 3k tune up.  Perhaps you're way past due.
CB550 K0
Offline Bankerdanny
  • Endeavor to persevere
« Reply #12 on: June 30, 2013, 08:00:37 AM »
You definitely need to take care riding on hot days. Air cooled engines and heavy traffic don't mix well.
I got caught like that one night on my '77 550. An accident had traffic stopped for long stretches and even though it was night it was still mid to upper 80's. By the time I got past the accident an could ride at a regular speed I could smell the heat coming off the engine and it was not idling well. Once you got it home and shut down you probably should have left it alone until the next day so it could fully cool off.
It is possible to overcook the oil and to seize up an air cooled engine in traffic. Sometimes the best thing to do is just pull over and shut it off for 10-15 minutes so that it can cool down. I sometimes shut mine off in traffic when things have gotten really bad. But you have to be confident it will re-start immediately to do that.
I would also be running motorcycle 20W-50 (regular though, not synthetic) for riding in the hot CA summer.
Offline felicious
« Reply #13 on: June 30, 2013, 03:07:33 PM »
I just got this oil:
http://www.amazon.com/gp/product/B008MISDEW/ref=oh_details_o00_s02_i00?ie=UTF8&psc=1
It looks like it's synthetic. Do you think that will be causing problems?
My next step will be to wipe the engine clean and follow the steps outlined in this post to locate the leak:
http://forums.sohc4.net/index.php?topic=77237.0
Offline toytuff
« Reply #14 on: June 30, 2013, 03:17:05 PM »
Wal Fart sells Valvoline 20/50 Motorcycle oil for under six bucks a quart.
tt
« Reply #15 on: June 30, 2013, 03:35:42 PM »
tt
Auto Zone $4
Offline toytuff
« Reply #16 on: June 30, 2013, 03:39:40 PM »
tt
Auto Zone $4
Don't deal with those idiots. At least not here.
tt
« Reply #17 on: June 30, 2013, 03:46:35 PM »
tt
Auto Zone $4
tt
My local A Z employees young females, I like.  I don't go to W M.
« Reply #18 on: June 30, 2013, 08:50:11 PM »
tt
Auto Zone $4
tt
just gotta jump in here and say that those are the two worst stores in the world today
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #19 on: July 01, 2013, 12:32:07 PM »
I buy Rottella T oil at Walmart for 12 bucks for 3.78lts. Just enough oil for a bikes oil change and you have a nice jug to recycle the old oil in...
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Bankerdanny
« Reply #20 on: July 01, 2013, 12:36:48 PM »
I like AZ just fine, but then I just want the parts. My local store is open 24 hoursm which is damn handy.
Felicious, that oil you linked to should work fine. It's made to work with wet clutches, so you should be all good.
Offline felicious
« Reply #21 on: July 01, 2013, 05:42:05 PM »
Thanks Bankerdanny for the confirmation.
« Reply #22 on: July 01, 2013, 06:00:37 PM »
It is not uncommon to have oil leaks on old cars when switching from dino oil to synthetic oil. Bikes resurrected from periods of not running can have oil leaks with normal oil.
Just need a synthetic that is wet clutch friendly. Auto oils often are not, while many synthetic MC oils are wet clutch friendly.
