Author Topic: What kind of triple trees are these?  (Read 1925 times)
Offline Scott S
« on: June 30, 2013, 04:22:14 PM »
 These are used on a couple of the Garage Co. bikes (awesome bike, IMHO). Any idea what they are from? Are they just using the uppers or a complete triple tree?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: What kind of triple trees are these?
« Reply #1 on: June 30, 2013, 08:39:35 PM »
my first guess is Ceriani...is there a pic that shows the rest of the forks?
« Reply #2 on: June 30, 2013, 10:13:04 PM »
Yup Ceriani roadrace, or also known as GP fork..  With the smooth top tree, you can also get them with handlebar mounts.. Prepare to pay a bit for a set.
 They look great , I love the look of them.
Offline CBcafeJunkie
  • 75 CB750F
« Reply #3 on: June 30, 2013, 10:32:47 PM »
Sexy.. and that tank is pretty awesome too.
« Reply #4 on: June 30, 2013, 10:45:12 PM »
If you can get just the trees, you can use them. With OEM forks..35mm.
Offline Scott S
« Reply #5 on: July 01, 2013, 03:08:06 AM »
 I have a folder full of these bikes, about four different ones. I know they won't handle the best, blah, blah, blah...but DAMMIT BOY!, are the not Bad A$$!
'71 CB500 K0
'81 Yamaha XS650
« Reply #6 on: July 01, 2013, 03:18:25 AM »
racers into the the '70's would certainly choose them over stock...so set up properly I'm certain they would be an improvement...but not necessarily enough of one to offset the collector value...
Offline Scott S
« Reply #7 on: July 01, 2013, 03:39:54 AM »
 I was speaking more of the bikes, than the forks. The bikes have slightly raked front ends and hard tail struts.
'71 CB500 K0
'81 Yamaha XS650
« Reply #8 on: July 01, 2013, 02:36:23 PM »
...perfect for drag racing, except too pretty...
« Reply #9 on: July 01, 2013, 08:08:02 PM »
They are streetdigger style..
Offline Powderman
« Reply #10 on: July 01, 2013, 09:14:58 PM »
That is the exact same fork set up I had on my XR1327 before I swapped over to late model Hawg Halter 4piston calipers. Ceriani forks, Hurst Airheart single piston calipers with those long brackets. That was the complete package for the brakes on Kimtab from the factory. Only difference is I have the handle bar mount top tree and those in the pic have the forks offset much more than mine.
« Last Edit: July 01, 2013, 09:19:21 PM by Powderman »
« Reply #11 on: July 01, 2013, 09:20:37 PM »
Are those plated?
Offline Powderman
« Reply #12 on: July 01, 2013, 09:21:29 PM »
Are those plated?
Mine are all polished. Chrome is nothing but unwanted weight and a #$%* to deal with when it goes bad. These just need a little TLC every now and then and they look brand new. I paid $100 for those forks brand new around 1975. They're worth 10X's that now or more when you can find them. There is one set of those wheels on Ebay right now for $1100.
« Last Edit: July 01, 2013, 09:24:51 PM by Powderman »
Offline Powderman
« Reply #13 on: July 01, 2013, 09:28:10 PM »
For a second I thought the smooth top tree might just be a lower tree with the "ARCES" name polished off but the lower tree uses a pinch bolt with a nut instead of just the bolt that doesn't protrude the other side,  plus the wholes for the stem are different.
