Right some of you may have read my build thread ....500/4 hadleigh custom
And just last weekend everything was fine....I'll skip,the boring parts..
And the rear chain gaurd broke loose dragging into the front sprocket...ending in a 30ish mph rear wheel lock up...
It screwed the clutch rod...and made a bit of a mess...
Well I made a new rod and fitted it back together tonight and all felt fine
Fired up the engine and is running as per norm
But I have no,final drive to the sprocket....it spins a bit when turning over but stops when engine kicks in....and when it's running with the rear wheel,up,you can flick through the gears and nothing changes....( it does feel like,the gears are selecting)
I then went to push the kickstart over by hand to,see what resistance I had and it just drops and does not seem connected to,the engine?
Everything feels normal nothing sounds busted on the face of it it's ok
So I have lost final drive .....
It's late now and I'm of to bed to,take my mind of it
Any ideas as to,the fault to look for first bearing in mind the cause.....
locking up solid from the rear wheel at relatively moderate speed,.....
