Author Topic: #2 tappet covers  (Read 2219 times)
Offline nccb
  • 1974 CB750 Four
#2 tappet covers
« on: July 02, 2013, 03:28:45 PM »
Anyone happen to have any pointers on getting some of the valve covers off?  I have removed all of them fairly easily with a 6 sided socket but I cannot get anything in for #2.  A member sent me a p.m. recommending some vice-grips which I will try out this week if the pb blaster I have been soaking it in for the past 2 days doesnt work.
I am thinking of adjusting all of the valves I have open, minus the 2, and running the bike whenever it dries up to heat up the casing.  Think a warm engine will help with the cover?  I know not to adjust it while warm but don't know what else to do.  My wife has allowed me to buy the things I need for maintenance, which subsequently included all the odds and ends I felt like needing ::)  I'd hate to have to get some more #$%*.  I tell her, "its just a matter of getting it back in shape, once that's done I won't be spending money on it. . ."
Offline Vinhead1957
Re: #2 tappet covers
« Reply #1 on: July 02, 2013, 03:49:57 PM »
Vice grips love to eat aluminum. Proper sized 6 point wrench. With the PB use some heat, hair dryer and gentle taps rubber mallet. Too much force will snap those threads right off.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: July 02, 2013, 03:56:00 PM »
I use a ring spanner.
« Reply #3 on: July 02, 2013, 04:06:30 PM »
I have gotten hard to get off ones that the PO had ruined the socket fittings by taking a large pair of good channel locks and grasping the outer edge of the round cap and turning. By grabbing the outer edge and not the center hex section you lower the risk of breaking the cap and then having to remove whats left of the threads and maybe losing metal down the hole.
Offline george
  • Back To My Roots !
  • K8 The Project
« Reply #4 on: July 02, 2013, 05:09:42 PM »
Sometimes after they have been so tight and dry the threaded ring will just stay in the hole , no big deal , gently nudge it out with a sharp screwdriver, watch the fingers as it is usually very sharp. The gentler the attack the more successful I have been.
If you need some pm me , got plenty , free .
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: July 02, 2013, 09:12:22 PM »
Did she buy it?!! ;D
Offline xsmooth69x
« Reply #6 on: July 02, 2013, 10:23:53 PM »
1975 CB550 (FINISHED?!?!?)
Offline nccb
  • 1974 CB750 Four
« Reply #7 on: July 03, 2013, 04:40:30 AM »
no :-[
bollingball
« Reply #8 on: July 03, 2013, 05:32:48 AM »
Those things are cheap plus you have a offer for a free one use some channel locks or vice grips and it will come right out. when putting them on after a tune up just finger tight plus a little more very little. Let the misses know tools are not just for a bike. Go in the bath room and loosen the big drain nut on the trap show her the leak and say darn if I just had some vice grips. ;D Delete this message right away ;D ;D
Ken
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #9 on: July 03, 2013, 06:03:31 AM »
The vise grips I am talking about are vise grip wrench's.  They clamp like vise grips but from three SMOOTH sides.  On both of my bikes the PO's had ate several of the tappet covers up and these things popped them right out.
http://www.irwin.com/tools/locking-tools/the-original-locking-wrenches
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline InTheStreet
  • Ha, you let me be a
  • When in doubt, flounder about.
« Reply #10 on: July 03, 2013, 08:47:50 AM »
Or you could do this.
If they start to round, don't tap a slightly smaller standard socket on and try to turn it.  If you do that, don't try to notch it for a screw driver bit and use an impact driver borrowed from a friend.  If you dothat, break a piece of the edge off and it'll spin out by hand.
It worked for me!  ???
1975 CB550K1
1980 CB650C (parting out)
1980 GL1100 (sold and missed)
bollingball
« Reply #11 on: July 03, 2013, 09:05:31 AM »
Problem is that excuse will run out real quick. Better off showing her that you need them for the house especially the kitchen they love their kitchen's.  ;)
Ken
« Reply #12 on: July 03, 2013, 09:31:16 AM »
Thats why channel locks around the outside of the cap works good,no breaking.
Offline nccb
  • 1974 CB750 Four
« Reply #13 on: July 03, 2013, 10:24:02 AM »
Thanks,  I guess the channel locks will need to be what I try. Problem with #2 is I can fit a socket in due to the frame sitting right over it.  I guess the exhaust valve I can undo the ignition switch but the intake valve is a #$%*.
Offline Steve_K
« Reply #14 on: July 04, 2013, 05:46:37 AM »
When you replace the covers, consider some new orings in the covers.  Mine were sort of square shaped and were over tightened to seal.
They were only some 40 years old and just did not hold up!(I'm in smart a$$ mode)
Steve
Steve_K
Offline nccb
  • 1974 CB750 Four
« Reply #15 on: July 04, 2013, 06:31:04 AM »
will do.  One thing for sure, these puppies are getting finger tightened and then just a nudge to 1/8" over that.  George, I may have to take you up on your offer ::)
Offline george
  • K8 The Project
« Reply #16 on: July 04, 2013, 09:29:38 AM »
No problem sir , let me know !
