Author Topic: Cylinder head ?'s  (Read 505 times)
Offline spiffy587
Cylinder head ?'s
« on: July 03, 2013, 10:00:28 PM »
Not sure where exactly to post this im new here. Anys i have a 77 cb750k, and i disassembled the engine for a rebuild. well now im at the point of cleaning everything to get ready for paint then reassembly. i pressure washed my head today, afterwards i noticed in cylinder 1 combustion chanmber it looks like something was bouncing around in there and chewed it up pretty good. just wondering if you can tell by the pictures im going to post if it is something i could repair or if the head looks junk? also noticed a divet in the valve cover surface, im sure that could just be welded up and ground flat. anyways here are the pictures, the hole on the valvecover side is next to the corner bolt hole.
Offline bjbuchanan
Re: Cylinder head ?'s
« Reply #1 on: July 03, 2013, 10:17:04 PM »
I would suggest a talk with Mrieck, he is the big cylinder head guy
The divot for the valve cover is odd, did you have the head sent out or did you do it yourself? It is pretty big in size, not just a tool mar
As for the chamber marks as long as sealing surfaces and the valve seats aren't chewed up it is "ok". "Ok" tho is a matter of opinion and everybody's is different. I would polish down any raised surfaces to not have hot spots and then sit the valves in place and test them with alcohol to see if they seal.
Offline spiffy587
« Reply #2 on: July 03, 2013, 10:25:48 PM »
i have not done any work to the head, just disassembled tonight and pressure washed. noticed those two things afterwards.
« Reply #3 on: July 04, 2013, 07:44:20 AM »
Check your carb for missing screws..
Offline spiffy587
« Reply #4 on: July 04, 2013, 08:04:14 AM »
i would love to do that but they are in a million pieces, getting cleaned, rebuilt and painted.
