Author Topic: HEADLIGHT CB550 K3 US/CANADIAN  (Read 1330 times)
Offline busa
« on: July 04, 2013, 09:22:40 AM »
Hi everyone  please can you help.
I have a 1978 cb550 k3  uk bike   frame and engine,   and a full wiring harness and electric plate and switchegears from a us/Canadian bike.
at the moment I have no ignition switch/key  no lights etc.  I have checked all the wires for continuity and they are all fine.  I have the Ignition wire plug jumped at the moment to give me power to everything.  I have the tail lights all working. using a test lamp.
now to the front.   I have flashers working  but will not flash.   think relay is faulty  (there is continuity on the grey and black. but nothing at relay)  running lights light up  again using test lamp.
But  I can not get the hi/low to work using test lamp.. on the blue wire or white wire  all the fuses are all okay as well
both switchgears are working fine   left hand one    (horn.  left/right turn  hi/low beam    right hand switch  kill/run  start
there is no winker buzzer attached.  but the blue brown has power.   should this also be plugged into Black??????
any help would be appreciated/
« Last Edit: July 05, 2013, 02:05:49 AM by busa »
Offline busa
Re: HEADLIGHT CB550 K3 US/CANADIAN
« Reply #1 on: July 05, 2013, 10:19:51 AM »
edit:-     sorry guys.   got it sorted.    it was a bad earth connection.   on new painted frame. and a duff battery
not holding its charge.
« Reply #2 on: July 05, 2013, 03:40:35 PM »
There are 2 earth points (grounds to our american cousins) one is the big wire direct from the battery to the rh rear engine mount--THIS NEEDS THE PAINT REMOVING ON BOTH SIDES WHERE THE BIG BOLT GOES THROUGH
The other is up by the coils which also needs the paint removing.
If you do not remove the paint on the engine bracket all the starter current goes via the small wire at the coils and fries the loom releasing the impossible to replace smoke
Offline busa
« Reply #3 on: July 06, 2013, 02:32:25 AM »
thanks for the info  would that be on the clutch cable mounting plate where it bolts to the frame and engine.
if so I will have to remove paint from the engine in that location as well  as the motor has also had new paint
Dhoooooooo..
I am not a dick head really!!!!!!!!
« Reply #4 on: July 08, 2013, 01:06:21 AM »
Yup thats the one, you aint the first and you only have to remove engine paint on the end of the boss where the bracket touches ---and BOTH sides of the bracket  so the ring end of the heavy duty cable has good contact right through to the alloy casing.
PS thats why the new brackets come without paint in that area!! Looks odd when you buy one
Offline busa
« Reply #5 on: July 08, 2013, 02:56:29 AM »
thanks bryanj  where about in the country are you!!!!!!!!
« Reply #6 on: July 09, 2013, 12:51:55 AM »
Gloucester mate, are you on the UK forum? I get to runcorn, well Preston Brook fairly regularly but normaly after midnight. The firm I work for has a depot there
Offline busa
« Reply #7 on: July 09, 2013, 02:06:50 AM »
don't think I am ??????????
do you know of any rocker end covers  any where!!!!!!!!!!!
Offline mickwinf
« Reply #8 on: July 09, 2013, 06:49:16 AM »
hi Busa I am in uk and might have some cam end caps, go on uk site sohc.co.uk use same username so we recognise you. lots of help on both forums but uk spec often differs from us spec, regards Mick
Offline busa
« Reply #9 on: July 09, 2013, 08:36:29 AM »
yeah will do thanks mick
also if you got them rocker end covers  how much
thanks
colin
« Last Edit: July 09, 2013, 09:44:53 AM by busa »
