Author Topic: Spark problems, kinda weird  (Read 1301 times)
Offline mono
  • Definitely no
« on: July 04, 2013, 05:11:11 PM »
 my 1+4 are getting a much smaller spark than 2+3, but 2+3 are barely getting warm.  Now I'm inclined to think that 2+3 are sparking TOO much, and 1+4 are normal.  ... I'm gonna switch the wires to see if the spark changes, but I need ideas.
New coil, new points and condensers, checked all the wiring... idk. I was riding it and all the sudden I lost power on 2 cylinders.... plug caps and plugs are new also.
Offline kghost
Re: Spark problems, kinda weird
« Reply #1 on: July 04, 2013, 05:26:14 PM »
Errr no.
There is no such thing as too much spark.
As you know one coil fires 1-4 and the other 2-3.
What you are describing sounds like a point gap issue.
Check the timing and gap.
Stranger in a strange land
Offline mono
  • Definitely no
« Reply #2 on: July 04, 2013, 05:36:19 PM »
LOL weird.  Just swapped back to my OLD condenser on the 2+3 and BAM.  instant working.
Sent from my SPH-L710 using Tapatalk 4 Beta
Offline mono
  • Definitely no
« Reply #3 on: July 04, 2013, 05:36:52 PM »
Ps the spark settled down a bit too.  I think it was grounding because the condenser failed.
Offline kghost
« Reply #4 on: July 04, 2013, 05:50:23 PM »
I think you found the problem. :)
Offline mono
  • Definitely no
« Reply #5 on: July 05, 2013, 04:51:01 AM »
yes, it just took me a lot of troubleshooting to figure out that my problem was on 2+3, not 1+4.  luckily it finally dawned on me that the 1+4 pipes were the ones getting hot even though i could barely see the spark, so i switched my focus to the other side and then it all became clear.  it would also explain the really weird resistance readings i was getting from the points -- i thought i was just doing something wrong with the multimeter!
