Author Topic: wiring issues.  (Read 1411 times)
Offline BRSmith
wiring issues.
« on: July 05, 2013, 07:05:52 AM »
 Trying to get the wives' 77 going.  The Neutral light is on all the time and the Drive light will not turn on. Bulbs are good. Another question, how fast should the signal lights flash? These flash very slowly... Thanks.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: wiring issues.
« Reply #1 on: July 05, 2013, 10:42:44 AM »
At the top of the 750A page - under schematics - is a change relay schematic.  Although this is for a 76, it is the same (as far as the gear lights) as for a 77.
If the neutral light isn't going out, and your L and D lights aren't coming on, then my first check would be the Changing Switch.  This switch is located under the left sprocket cover - but there should be two wires coming out that area that not part of the plug (that also comes out of that area).  The two wires have individual bullet connectors on them.  The wire colors are Brown/Red and Blue/Yellow.  When measured to ground, the Blue/Yellow should be shorted to ground while in Low (open otherwise); and Brown/Red should be shorted to ground while in High (open otherwise).
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
