Author Topic: '76 CB750K Project #3 - Long and Low - Final thoughts and pics  (Read 46808 times)
Offline Stoli
Re: '76 CB750K Project #3 - Long and Low
« Reply #50 on: July 29, 2014, 07:41:23 PM »
Finally cleaned up the engine. Now the fun starts...
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Stoli
« Reply #51 on: August 01, 2014, 12:29:15 PM »
My Project Threads:
Offline Stoli
« Reply #52 on: August 10, 2014, 02:19:11 PM »
Carbs are done. No leftover parts! Took longer than I thought. They were in pretty bad shape. Hopefully I got all the passages clean.
Here are some before and after pics:
At first I polished the tops and bowls to a mirror finish but it wasn't the look I wanted. I don't want this bike to look too shiny, so I dulled them a bit to bring out some of that patina that builds up over the years. The velocity stacks stand out a bit more but I'll go with this for now and change it later if I don't like the looks of them on the bike.
My Project Threads:
Offline Stoli
« Reply #53 on: August 21, 2014, 04:50:26 PM »
The good news is that I made a seat cushion. The bad news is that I don't like it very much. I'm hoping it is just because the seat pan that it is sitting in isn't finished yet and it makes it look awkward. It is my first attempt at pleats (or whatever you call them). My hats off to the upholsterers who make this look easy. The vinyl is an ostrich texture. That might have something to do with it. Too shiny for this bike? I won't be able to tell until after I paint the seat pan.
Fiberglass bottom plate that sits pefectly in the saddle:
Two layers from a yoga mat that I hope my wife won't miss:
Finished product:
« Last Edit: August 21, 2014, 07:55:42 PM by Stoli »
My Project Threads:
Offline BPellerine
« Reply #54 on: August 21, 2014, 05:15:40 PM »
no need to worry it looks great!bill
1978 CB 750K ard and webers
another anfob
Offline Coyote13
« Reply #55 on: August 21, 2014, 05:26:07 PM »
Once you get the pan finished that's gonna look reaaaaaaaal niiiiiiice.  Has a bit of a WrenchMonkees stance from the side, and I dig it!
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline Stoli
« Reply #56 on: August 21, 2014, 06:16:46 PM »
Thanks guys. I almost threw my wife's sewing machine out the window when I was making it so I hope it works.
I worked on the pipes this afternoon. I am more optimistic on that front. The headers are from a 78K. The mufflers were all rusted out so I cut them off and added a small length of stainless pipe that fit perfectly over the old headers. Slash cut the ends. The headers are still pretty rough so I plan on wrapping them to just aft of the foot pegs and leaving about 9-10" of the stainless exposed. I think it will work OK. I have some baffles for them which hopefully will make it easier to tune the carbs.
My Project Threads:
Offline Stoli
« Reply #57 on: August 21, 2014, 06:21:28 PM »
Forgot to mention that I did have to tweak #2 and #3 headers a bit to get them to line up right. Lots of heat and a nudge or two and they seem to have the right lines.
My Project Threads:
Offline Stoli
« Reply #58 on: August 21, 2014, 07:18:48 PM »
I must admit that WrenchMonkees rebuilt an old sportster that caught my eye and has certainly influenced the direction of this project. Glad you noticed. I guess that means that I am close to what I envisioned when I started. Albeit a v-twin and an inline 4 are sort of apples and oranges.
My Project Threads:
« Reply #59 on: August 21, 2014, 07:20:06 PM »
Unless you run struts on the back you are going to have trouble with the rear tire hitting the guard. Have you used those tires before..?  more show than go....{and thats putting it mildly}
Offline Stoli
« Reply #60 on: August 21, 2014, 07:27:03 PM »
The oil tank can be moved forward a bit and the fender trimmed if needed. If I wanted more go than show, I'd ride a new BMW. Thanks for your concern though.
My Project Threads:
Offline Stoli
« Reply #61 on: September 11, 2014, 09:09:11 PM »
Time to run some wires.
No big headlight bucket on this bike to hide the nest, so will make most of the connections under the tank.
My Project Threads:
Offline brandEn
« Reply #62 on: September 11, 2014, 09:10:58 PM »
I do not envy you right now, I hate wiring.
Have fun!
Offline Stoli
« Reply #63 on: September 11, 2014, 09:12:22 PM »
The battery, regulator/rectifier, fuses and headlight relay fit nicely under the seat.
My Project Threads:
Offline brandEn
« Reply #64 on: September 11, 2014, 09:13:45 PM »
WOW thats slick!!!!!! This project looks really good. I have been missing out.
Offline Stoli
« Reply #65 on: September 11, 2014, 09:18:51 PM »
Have fun!
 ;D  I don't mind it when I have a plan and the flow starts making sense. It's getting started that is a bit painful. It's amazing how many wires there are on such a simple bike. Seems like half the wires are for the directionals.
My Project Threads:
« Reply #66 on: September 11, 2014, 09:22:15 PM »
Very tidy and very practical with the ventilation.
Offline Stoli
« Reply #67 on: September 11, 2014, 09:37:36 PM »
Thanks. It's coming together pretty good. The new battery tray as well as the seat both mount up using existing holes (old battery box mounts) with no fancy mods. I'll get some pics up in the near future, but basically you pop the seat cushion off to reveal 2 screws that hold the seat/fender in place. (The seat pan sits on 4 rubber blocks) The battery tray is held down by a single screw (also using the old battery box mount) and is kept from sliding  by the same 2 screws that hold down the seat.
« Last Edit: September 11, 2014, 09:45:12 PM by Stoli »
My Project Threads:
Offline iron_worker
« Reply #68 on: September 12, 2014, 09:20:09 AM »
That electrical tray is slick!
IW
Offline Stoli
« Reply #69 on: September 12, 2014, 04:10:34 PM »
I hate brakes! I don't know why they are so difficult for me. Seems like a simple task. Get all the air out of the lines and your done. Well, I have a Mightyvac and a Speedbleeder and it is still pure f$%king hell to me. After a few hours trying different things, I wound up disconnecting everything from the bike, holding the caliper over my head and was able to get the air out of the line. Why is it so f$%king difficult? Anyways, front brakes are done.
My Project Threads:
Offline Stoli
« Reply #70 on: September 12, 2014, 04:12:01 PM »
Now, electricity, that is a different story. Love the electrons...
Modified the PAMCO so I only need to run one group of 3 wires up to the coils. It would be nice if they had this option. I wouldn't mind paying a little more if that was the case. It would also be nice if they gave you more than 2 feet of wire. It's barely enough to get to the coils - unless you run them straight up the side of the engine ;D
My Project Threads:
Offline Stoli
« Reply #71 on: September 15, 2014, 04:46:10 PM »
The 76K finally emerges from the basement workshop. Ready to experience a new life on the road.
My improved basement extactor worked well. A one man operation. Not bad for a $50 Harbor Freight winch and a motorcycle battery.
« Last Edit: September 15, 2014, 04:50:30 PM by Stoli »
My Project Threads:
Offline BPellerine
« Reply #72 on: September 15, 2014, 04:54:39 PM »
is it ready to fire up?bill
another anfob
Offline MoMo
  • Ride like you're invisible
« Reply #73 on: September 15, 2014, 05:45:03 PM »
That extractor is awesome, brilliant bit of good ole Yankee engineering you did...Larry
Offline brandEn
« Reply #74 on: September 15, 2014, 05:56:41 PM »
Nice work!
