Author Topic: CB750 Cyl Hd oil jets  (Read 2852 times)
Offline 01Thomas
« on: July 08, 2013, 01:38:31 PM »
Hi
We know that these heads came out with two versions of the oil jets; I'm talking about the jets that meter the oil flow to the cam bearings etc.
There is the smaller one with a diameter of about 5mm; let's call it Type 2.
There is the later version with a diameter closer to 8mm; let's call that Type 3.
However, I have just come across a head where there is no inserted jet. Instead the oil flow seems to be controlled by a narrow passage between the head surface and the stud cavity. The head surface is recessed by about 1 mm. Anybody come across this before? Can we call this Type 1?
I've attached photos, the first is as found and in the second photo I've pushed a pin into one of the two passages.
regards
Thomas
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline 01Thomas
Re: CB750 Cyl Hd oil jets
« Reply #1 on: July 09, 2013, 01:50:49 PM »
Last night I had issues with my ISP so my first photo didn't come through but here it is now: this is the oil jet/metering orifice without an insert of any sort, and without my bent-open safety pin in it. The round recess in the head is obviously to take a o-ring and it's only about a millimetre deep. The head has been badly stored and is quite dirty. It is very obviously an early head as it doesn't have the extra bolt-hole in front.
Has anybody come across such a CB750 head before? Is this a sandcast head, or maybe a prototype? Frank? Mrieck?
Offline fire113
« Reply #2 on: July 09, 2013, 02:51:44 PM »
...I have a sandcast head and the oil jets looking like a drilled hole, nothing to remove or to insert, just a small hole.
EDIT ...found a picture of the firs insert type.
« Last Edit: July 09, 2013, 02:57:54 PM by fire113 »
« Reply #3 on: July 09, 2013, 07:14:22 PM »
Quite possibly sandcast.....it is the earliest example of 750 heads.
Offline 01Thomas
« Reply #4 on: July 10, 2013, 08:55:37 AM »
Thank you, Fire113 & MRieck
Do these heads have any value?
« Reply #5 on: July 10, 2013, 02:44:55 PM »
Yes
