Author Topic: Melting Kickstand Rubber  (Read 1263 times)
Offline NShahdadi
« on: July 10, 2013, 06:08:15 PM »
So, it's been relatively hot here in Missouri for the past week or so and I've started to notice that the rubber foot on my (550) kickstand is melting a little bit onto my (stock) pipes.  :o
Anyone else have a problem with this? I assumed that rubber was made to withstand some pretty hot temps.
1976 CB550K
Offline canonball
Re: Melting Kickstand Rubber
« Reply #1 on: July 11, 2013, 08:29:38 AM »
I'm basically a noob compared to the others on here but that sounds uncommon. I live in FL and we get some pretty nasty heat and I've never had this happen with either of my bikes. There's a few ebay listings for these if you end up replacing it, other than that I'm not much help
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: July 11, 2013, 08:39:44 AM »
I don't have rubber feet. :)
Offline NShahdadi
« Reply #3 on: July 19, 2013, 09:53:00 PM »
Bump. Anybody have any ideas?
1976 CB550K
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #4 on: July 19, 2013, 10:24:55 PM »
Isn't there a rubber bumper that fits on the bottom of the exhaust?  I think its item 61 on the muffler parts list (Bike Bandit).  I thought that the kickstand hit that before it could come into contact with the exhaust.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline NShahdadi
« Reply #5 on: July 19, 2013, 10:57:15 PM »
There's definitely one for the center stand but I don't believe there's one for the kickstand. Unless I'm mistaken. Just strange that is only happening all of a sudden.
1976 CB550K
Offline surveywaters
    • My Project Photos
« Reply #6 on: July 20, 2013, 08:46:49 AM »
Sounds really hot, any new discoloration on the header? Check the plugs.
1972 SL125,1974 XL125,1975 CB125,1978 CB750k,1978 KZ650,1978 XS650,1985 VT1100,1986 VF700, 2005 XV1700,2003 DL1000,1982 XR250R,1986 ATC70,1987 BW80,1987 XR250R,1999 Z50r,2002 DRZ400s
« Reply #7 on: July 20, 2013, 08:54:46 AM »
I don't know about the 550 specifically, but from a design/engineering standpoint I can't imagine Honda ever designed something that could touch the pipes. Must be a stop missing or its a stand from a different model year etc.
Just doesn't sound right.  Check a microfish.
Offline NShahdadi
« Reply #8 on: July 20, 2013, 08:27:50 PM »
Good point. I'll check for any missing parts on the micro tomorrow. Thanks!
1976 CB550K
Offline Bru-tom
« Reply #9 on: July 20, 2013, 11:34:33 PM »
I TIG welded shaped pieces of stainless steel and my kickstand and centre stand "feet".. long lasting and willn never rust :D
Offline Bodi
« Reply #10 on: July 21, 2013, 07:35:32 AM »
The rubber should not touch the exhaust. The rubber tip is there to kick the stand out of the way if you try and ride away with it down, instead of possibly jacking the bike into the air on your first left turn.
Anyway, something is wrong. If you have the stock exhaust I suspect the stand itself is bent or the pivot has been bent or damaged, possibly that part of the frame is rusted and weak allowing the pivot to shift (this is a typical spot for internal frame rust since water will collect there if it gets inside the tubing).
