Author Topic: 78 550 K4 - What Rear Tire?  (Read 783 times)
Offline K3Owner
« on: July 11, 2013, 03:33:16 PM »
Hi list,
The very cheap, mounted in the 90s, Cheng Shin has finally worn thin on the rear. I replaced the front this year with the Avon Speedmaster - very much like the original.
Anyone have any experience with a tire combo that includes this front and what do y'all recommend for a rear replacement in any case? I like to try to keep it as original as possible. Thanks!
1978 CB550K4 - yeah, I'm not a K3 Owner - my bad
Re: 78 550 K4 - What Rear Tire?
« Reply #1 on: July 11, 2013, 04:13:03 PM »
Offline K3Owner
« Reply #2 on: July 12, 2013, 01:58:18 AM »
Thanks Stev-o - I also see that there is a K81 that has a central quiet rib. Can you compare it to the K70? I see the 81 is tubeless...
No, I don't think you're a tire guru but appreciate any experience you can lend. My logic - front and back with center grooves means quiet running but I don't want to make the bike unstable.  '78 550K
« Reply #3 on: July 12, 2013, 02:55:55 AM »
use a matching avon rear,you ran a mid 90s tyre?
« Reply #4 on: July 12, 2013, 06:15:45 AM »
This would be the matching rear tire, I don't like the pattern, nothing like original.
http://www.motorcycle-superstore.com/3/31/401/14793/ITEM/Avon-SM-Mark-II-Rear-Tire.aspx?WT.ac=SLIsearch
Sorry, no tire guru here, but have been shopping for tires recently for my RD350 and want a vintage tire as well. I'm having trouble finding an 18" front though.
I recently bought Avons AM26's for my Z1, but that is a modern looking tire, wanted the best handing tire for it, needs all the help it can get!
Offline K3Owner
« Reply #5 on: July 12, 2013, 07:08:08 AM »
Dave500 - it was a Cheng Shin 110/90 recommended by some store back in New Jersey in the early 90s. That was years before I escaped that state and when I wouldn't risk tire irons. The front tire they recommended wasn't even a good fit. I scrapped that a few months ago. I had a 1200 Bandit and put 30K on it instead of the CB so the tires have lived for a great while. The little 550 is now my one and only. The Avon rear is an option but I do prefer the OEM appearance.
Stev-o - I wish I could locate a 3.75 but it seems they've gone the way of the do-do. 4.00 will have to do and is close enough. Good luck in your search!
Thanks guys!
« Reply #6 on: July 12, 2013, 04:03:56 PM »
Hard to find a 3.75, hey, it's only a quarter inch wider.
I think I'm going with IRC, anyone have an opinion? Their not Chinese made.....
http://www.amazon.com/IRC-GS11-Front-Motorcycle-3-00-18/dp/B003Y8F9KG/ref=pd_bxgy_auto_img_y
Nic
« Reply #7 on: July 12, 2013, 04:10:51 PM »
I'm going K81s for my 750, will be buying real soon.
Offline K3Owner
« Reply #8 on: July 12, 2013, 04:41:15 PM »
Central rib so quiet. No experience with IRC. Can't be worse than Cheng Shin...
Offline KC_Northstar
« Reply #9 on: July 12, 2013, 04:47:37 PM »
I wanted the vintage look on my CB750 K1, so I went with the Avon Speedmaster front and Dunlop K70 on the rear.
I'm real happy with that combo.  Both great tires and they work well together.  Handle pretty good.
KC
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
« Reply #10 on: July 12, 2013, 05:10:11 PM »
Is a quiet tire really a concern? You must have a very quiet stock exhaust and not ride over 4K RPM?
« Reply #11 on: July 13, 2013, 03:13:28 AM »
nothing wrong with cheng shin,i just put one on this ride,its a 450-400x8,its awsome!
Offline K3Owner
« Reply #12 on: July 13, 2013, 05:31:20 AM »
That barrow will be difficult to steer in the corners! As for the 550, I keep her to the back roads and in high gear so 4500 is typical and the exhaust is bone stock and 'perfect'. I guess I wouldn't hear the rear tire over the tappets so, yup, probably not an issue. Sounds like the K70 is the way to go.
« Reply #13 on: July 13, 2013, 05:38:27 AM »
Awesome tire, Dave.  Available in an 18"??
Offline Lostboy Steve
« Reply #14 on: July 13, 2013, 06:17:17 AM »
I had cst's on my brothers ninja500 and he took a pretty bad spill around a corner. Don't know if it has anything to do with the tire, but possibly? He's been fine on the Michelin pilot sports since.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
