Author Topic: Charging help  (Read 1939 times)
Offline zuehl666
Charging help
« on: July 13, 2013, 09:11:31 PM »
1971 cb750 k1, new reg rec combo, new battery, all custom wiring harness. So the issue I'm having is figuring out where I should wire in the field coil wires. The green and white from the stator. I have the three yellows to the three yellows on the reg/rec. the red to batt positive and the green to ground. I'm not sure where the field wires should be, I have a black and a white on the reg, when I hook the black to field green and white to white it doesn't charge. I tired black reg and field green to negative batt terminal and it over charges. Any ideas how this should be done?
Offline Spanner 1
Re: Charging help
« Reply #1 on: July 13, 2013, 10:38:45 PM »
Dude you bought a rectifier only, no regulator if your wires ( as stated ) are yellow x3 and green and red...
Offline bjbuchanan
Re: Charging help
« Reply #2 on: July 13, 2013, 10:47:42 PM »
If "set up" for stock honda it is gonna be green as the ground, black as the switched hot wire (for the reg/rect possibly a hot 12v sense wire) and also the white wire to the white. You gotta hook that black to the "type" of wiring it should be, not a ground but a hot switched wire
Offline Bodi
Re: Charging help
« Reply #3 on: July 14, 2013, 06:06:25 AM »
Need a bit more info: with an "all custom wiring harness",  it's really hard to diagnose from here.
I assume you have an aftermarket regulator/rectifier, since the stock one doesn't have coloured wires.
The R/R black wire is for the power to run the regulator: it has to be connected to what would be a black wire in a a stock harness - switched "ignition" +12V battery power. The regulator electronics use some power and the field coil uses a lot of power, so the regulator needs this switched power. If the black is connected to unswitched battery +,  it would power the field coil and discharge the battery with the key (and engine) off.
Then for your two field coil wires: green gets connected to ground (green wires should only be used for ground connections). White goes to the white wire from the reg/rect.
Note that by connecting assorted things to the reg/rect white and black wires you may have destroyed the unit.
Also, if you didn't get a reg/rect specifically sold for the SOHC CB750 system it may need a "reversed" field coil connection. The later (1980+) DOHC CB750/900/etc bikes used this system - you can use a reg/rect from or for these bikes but the field coil wiring is slightly different and requires modification of the stock harness to use in a SOHC model.
Offline zuehl666
Re: Charging help
« Reply #4 on: July 14, 2013, 08:20:57 AM »
Thanks a lot, thats very helpful. I think I know where I went wrong now. I bought the reg/rec combo for that bike from dime city which should be a direct replacement but I made a custom harness so it's a little trickier. I had the  black from the reg in the wrong place so it wasn't powering the regulator.
Offline cheftuskey121
  • Super Newbie
Re: Charging help
« Reply #5 on: July 14, 2013, 08:48:28 AM »
Not to go too off topic but have you updated your build thread? I love the look of your bike man!
Offline zuehl666
Re: Charging help
« Reply #6 on: July 14, 2013, 04:37:54 PM »
I will tomorrow. I'll upload some new pics. I had a couple issues to work out with the tank, but it's all done now. I just have to fix the charging issue and put new tires on.
Offline zuehl666
Re: Charging help
« Reply #7 on: August 02, 2013, 06:48:59 PM »
Ok, so I had to order a new reg rec because I fried the first one by wiring it wrong which we had discussed. I ordered the same one I did last time, says on the description on the site for 750k BUT when I got it I see the wires are slightly different and 750K is not listed on the box. Do you think brown-reg to switched positive and green-reg to white from field sensor? Then green from field sensor to ground??
Re: Charging help
« Reply #8 on: August 02, 2013, 08:40:16 PM »
This is a generic regulator; the 650 has a different system than all the other SOHC 4s, and the color codes don't match any of them. My best educated guess would be to wire the red to battery +, the black to chassis ground/battery -, white to the white field wire ("phase input from stator" makes no sense at all), green to the green field wire (directly, not grounded), and brown to switched ignition.
Offline Xnavylfr
Re: Charging help
« Reply #9 on: August 03, 2013, 05:26:35 AM »
Since there are 3 white wires, they hook to the 3 yellow wires from stator.The brown and green also hook to the wires from the stator.
This may help ,but remember this diagram is for a DOHC R/R to SOHC wiring.
http://www.hondachopper.com/garage/reg_rect_diagram/reg_rect_diagram.html
The BROWN may hook to the white  wire and green to green from the stator. The diagram has 8 wires and yours has 7 , it shows an extra wire to juice the R/R from the IGN.
Xnavylfr(CHUCK)
Offline Spanner 1
Re: Charging help
« Reply #10 on: August 03, 2013, 10:21:00 PM »
Here ya go....
RED to battery +
BLACK  to ground ( use green @ 'old' regulator )....( Honda uses Green as ground....)
BROWN to black ( from 'old' reg. )..... ( Honda uses Black as 12v when ign. 'on' ... )
GREEN to white ( from 'old' reg. ).... ( White is the power feed to the field coil... )
3 x WHITE to 3 x yellow ( no order to which white to which yellow )
« Last Edit: August 03, 2013, 10:28:18 PM by Spanner 1 »
Offline Xnavylfr
Re: Charging help
« Reply #11 on: August 04, 2013, 05:33:20 PM »
Offline zuehl666
Re: Charging help
« Reply #12 on: August 05, 2013, 07:34:09 AM »
This was the correct way, I was getting thrown off because my battery was draining when the bike was off. I thought i didnt have the brown hooked up to a switched positive. Turns out the battery is just draining by itself with no parasitic draw. When its off the bike and on a charger it starts to deplete as soon as i take the charger off. Its brand new, i'll have to try to exchange it.
Here ya go....
RED to battery +
