Author Topic: How to clean stock exhaust pipes?  (Read 2126 times)
Offline PhillyCb750K3
« on: July 15, 2013, 04:35:17 AM »
Hey guys,
I'm a newbie to bikes and I'm in need of some help. I first searched around the forum for a write up on this with no success. I recently picked up some stock cb750 exhaust pipes which show little rust on the outside. I want to clean them up and possibly extend the life of them. Does anyone know how I should go about this? What products should I use on the outside and inside? If you could provide some basic steps, that would be awesome too.
Thanks
John
Re: How to clean stock exhaust pipes?
« Reply #1 on: July 15, 2013, 06:00:29 AM »
Assuming the outside is chrome, try spraying WD-40 on them, it is a very good cleaner.
And on the rust, use 000 steel wool along with the WD.
Then some chrome polish will keep them looking good.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: July 15, 2013, 06:03:00 AM »
A Dremel tool with a wire wheel attachment works really well along the crevices.  I use 0000 steel wool...Larry
Offline Lars
« Reply #3 on: July 15, 2013, 06:22:59 AM »
When comes to the inside, my friend and I once decided to clean the muffler on his Vespa 125 1964 model. We took the muffler off and poored white spirits inside. Then we shaked it long and well, we could work in a cocktail bar after that. Poored out all the stuff in a bucket, a lot of black dirt and whatever came out of it. Then we installed it all back on the Vespa.
We started up and down the road we go, he drives and me on the back seat. After a few hundred meters he looked in the mirror and said to me; look back! I looked back. We could not see the road, due to an enormous amount of exhaust. After a while the visibility behind us cleared up a bit and we pulled aside. The Vespa was idling and the muffler was blowing out smoke rings, just as the experienced guys did who were smoking cigarettes.  ;D ;D ;D
We had great fun of that trip, but I can't remember if the cleaning prosess gave any significant change of performance when it comes to power. Maybe you can try and keep us updated. We did not have cell phones at that time, so pictures would be great, too! ;)
...if you got the ability to act...
Offline 74750k4
« Reply #4 on: July 15, 2013, 09:28:38 AM »
steel wool, and wd-40. Seems to be the best solution. Fixing the oil leaks helps too :)
Offline wristpin
« Reply #5 on: July 22, 2013, 06:53:56 PM »
After a good cleaning use aluminum foil and coca cola.
