Author Topic: adjusting valves...proper setting?  (Read 722 times)
Offline oldk6guy
  • old bike
  • is this ever really done?!
« on: July 15, 2013, 09:30:19 AM »
i have the original owners manual for the bike and it says to set the valves to int. 0.05mm or 0.0019in and exh at 0.08mm or 0.0031in. there is no way that is correct. i dont believe that a feeler gauge has ever been made that thin....any help would be greatly appreciated.
76 cb750 k6: 4 into 4 exhaust, open air horns on carbs.
Offline oldk6guy
  • old bike
Re: adjusting valves...proper setting?
« Reply #1 on: July 15, 2013, 09:32:35 AM »
bike is 76 cb750k6
Offline 74750k4
« Reply #2 on: July 15, 2013, 09:42:43 AM »
Factory recommended values:
INT .003" or, .0762 mm
EXH .004" or, 0.10 mm
Many run .005" all around.
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: July 15, 2013, 09:47:21 AM »
They make em....   impossibly thin and easy to crease, but they make them.    Try Napa.
Offline RebelYankee
« Reply #4 on: July 15, 2013, 10:26:12 AM »
1980 CB650C
Offline oldk6guy
  • old bike
« Reply #5 on: July 15, 2013, 11:13:20 AM »
are there benefits from going .005?
Offline iron_worker
« Reply #6 on: July 15, 2013, 11:42:56 AM »
More gap will result in:
-Less total lift
-Less open duration
-More time on the seat (allows heat rejection from valve to head... less burnt valves)
-More valve noise
IW
Offline Dave Voss
« Reply #7 on: July 15, 2013, 12:34:13 PM »
I adjust the valves to .003" INT and .004" EXH, which is 1 thousandth more than the factory setting.  Besides the benefits listed above, it also provides a bit of extra protection against loosing compression if the engine overheats enough to close up the smaller stock valve clearances.  Granted, that is an unusual circumstance, but it can happen under high load in really hot weather if the carbs are running lean for any reason.  At the slightly larger valve clearances, the valve train noise is just slightly more when the engine is cold, but about the same as stock once it is warmed up.
-Dave Voss
(past) '78 CB550K4
(past) '75 CB550K1
(now) '95 R1100RSL
Offline tomkimberly
« Reply #8 on: July 15, 2013, 02:11:27 PM »
+1, always set them large on these old bikes.
Tom
