Author Topic: Clutch basket spring tension  (Read 1574 times)
Offline stereosilence
  • 1975 CB550K
« on: July 15, 2013, 05:44:47 PM »
Under the plate that holds the clutch basket on, there are 4 springs under 4 bolts. Do I tighten these 4 bolts all the way down?
Offline Kenzo1979
Re: Clutch basket spring tension
« Reply #1 on: July 16, 2013, 04:41:34 AM »
Yes, tighten them all the way down.  Torque them to the recommended torque for that size bolt (6mm).  Honda manuals give a torque requirement for a lot of things, some manuals don't have a torque requirement for certain bolts, but there is a section showing general torque values based on the bolt size.  I don't remember what the values are off hand but I think for 6mm, it's around 8ft/lb.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Kenzo1979
« Reply #2 on: July 16, 2013, 04:51:47 AM »
Here ya go:  5.7 - 8ft/lb
--Kenzo
Offline Kenzo1979
« Reply #3 on: July 16, 2013, 04:52:43 AM »
BTW, it's #20 on the pic.  Sorry forgot to say that.
--Kenzo
  • 1975 CB550K
« Reply #4 on: July 16, 2013, 05:45:10 AM »
I don't have a torque wrench. Guess it will just be a bit more than finger tight. :)
Thanks for the help.
Offline tool14
« Reply #5 on: July 16, 2013, 05:48:30 AM »
go slow and a little at at time on each bolt or you can crack the plate.
