Author Topic: clutch rattle that doesn't soften with clutch in  (Read 397 times)
Offline ben_j
« on: July 19, 2013, 12:33:08 AM »
maybe the subject line says it all.
I've got a clutch/transmission rattle on my '75 CB750F that quietens a little (but not much at all) when I pull the clutch in. What do you reckon my problem (with the bike) is?
Also, noticed today that the engine on the side of no.4 cylinder gets a lot hotter quicker than the no.1 side. Thoughts?
Thanks guys/gals
Ben
Re: clutch rattle that doesn't soften with clutch in
« Reply #1 on: July 19, 2013, 01:10:20 AM »
carb sync out?rattle is then more primary chain.
Offline Bailgang
  • Scott
  • Indiana
« Reply #2 on: July 19, 2013, 01:36:12 AM »
+1 on that.
You wouldn't think out of sync carbs could make an engine so noisy but it can make an engine sound like a bucket of bolts. I split the case on my 550 and installed a new primary chain which did quite things down but the engine still rattles at idle if the carbs are out of sync.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #3 on: July 19, 2013, 02:27:37 AM »
I'm guessing that it's not running well on #1. If it's only running on 3 cylinders (or only firing occasionally on #1, hence the cooler pipe) it'll rattle like a bastard! I had a real rattle on my F2, which turned out to be a clagged starter motor. Cheers, Terry. ;D
