Author Topic: '74 750 k firing on all cylinders but 4  (Read 704 times)
Offline eliasjklein
« on: July 19, 2013, 08:49:24 PM »
Hello there, so just finished putting together my cb750 (1974), full resto, new cam, pamco elec. igntion, plugs, wires, coils, the works. For about a week it was running fine then number 4 stop firing, the exhaust is not nearly as hot as the others, I have pod filters and a 2 into 1 exhaust, running 120 main jets. Will a new spark plug fix the issue or is there another problem I should be looking at? Like the number 4 carb? I'm all out of ideas. Thanks for reading.
Re: '74 750 k firing on all cylinders but 4
« Reply #1 on: July 19, 2013, 10:22:37 PM »
Have you checked for spark on 4?
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
« Reply #2 on: July 20, 2013, 03:58:30 AM »
sounds like plug,do you have a spare to try
« Reply #3 on: July 20, 2013, 04:26:38 AM »
Your spark plug cable is freshly cut too?
Offline eliasjklein
« Reply #4 on: July 20, 2013, 08:10:26 AM »
I went to get new plugs and they should be here for Monday, the new wires are new and quite long, I could try re cutting them see if that helps, I've put in a few new plugs already, it seems to be fouling them
Offline kpier883
  • is quite the
« Reply #5 on: July 20, 2013, 09:06:46 AM »
If they are black and sooty you might be running rich.  I have a stock '74 except for aftermarket 4:2 pipes.  It fouled plugs regularly (with 110 mains) until I went to 105s.  MPG improved too.  In my case I also changed the #40 idle jets to a smaller size because it never needed the choke to crank, which indicated rich to me.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline eliasjklein
« Reply #6 on: July 21, 2013, 07:59:47 AM »
I got it running nicely now, new plug did it, running 120 mains, air screw is backed way out, I think its still running rich though, I've heard with pod filters it will run a bit leaner
