Author Topic: 12 mm (M12) rear wheel sprocket stud torque?  (Read 848 times)
Offline VTCBike750
« on: July 20, 2013, 03:51:41 PM »
So, I had 3 of the rear wheel studs that hold the sprocket on come out with the nuts. Does anyone know what I should torque the studs to? Its for a 93 nighthawk 750, 12 mm studs
The Clymer manual I have recommends torquing 12 mm bolts and nuts to 41 ft/lb, sound right? Thats seems a bit excessive.
« Last Edit: July 21, 2013, 04:47:24 AM by VTCBike750 »
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline FunJimmy
  • Who you calling
  • Vancouver
I'm assuming that a 12mm bolt is actually am M8 fastener.
If so, the torque spec is approx. 20 ft lbs.
Offline VTCBike750
Nope, it is an M12 fastener.
-Adam
Offline tlbranth
Torque on a stud really doesn't matter. Just tighten it with some blue locktite on the threads and then torque the nut.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline VTCBike750
Re: 12 mm (M12) rear wheel sprocket stud torque?
« Reply #4 on: July 21, 2013, 04:50:19 AM »
That makes sense. The pressure of the Flange Nut on the whole system should prevent things from back out.
Done and Done. I torqued them done to 15 Ft/lbs, but with blue loctite. Thanks for the advice.
Adam
-Adam
