Author Topic: Problem getting into 5th / staying in 5th  (Read 841 times)
Offline SKTP
« on: July 20, 2013, 04:33:16 PM »
So I'm about 50 miles in on an engine rebuild (rings gaskets) and a tranny swap from eBay.
The bike is running well and shifts perfectly from 1st to 4th but then in 5th it pops in then out then I can put it back in and it falls back to a "false nutral" and then will go back in to 5th.
It will stay in 5th but I never know when it will disengage...
I am running the bike in the low RPMs and really if the engine was broken in I would not be shifting into 5th when I am....but I figure it should still stay there.
I'm guessing it a worn shifter fork or dog and I should have measured all the tranny-swap parts...but maybe there's something I can do/try without splitting the cases?
Wishful thinking?
« Last Edit: July 20, 2013, 04:34:47 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: Problem getting into 5th / staying in 5th
« Reply #1 on: July 20, 2013, 05:08:16 PM »
What oil are you running? Seriously...not trying to derail this into an oil thread but proper oil facilitates easy shifts.
Odds are you have a bearing or for that 5th gear's dogs...
Unless oil fixes it, you will be splitting the cases to go through the gearbox.
Offline SKTP
« Reply #2 on: July 20, 2013, 05:13:48 PM »
I will be doing an oil change after I go through my first tank of gas (that's around 100 miles)...
What do you recommend? Pandora's box!!!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #3 on: July 20, 2013, 05:52:01 PM »
MOTUL 7100 or Castrol Act-Evo 20w50
Offline SKTP
« Reply #4 on: July 20, 2013, 05:58:22 PM »
Right now it has Quakerstate 10w40 in there. Not synthetic.
« Last Edit: July 30, 2013, 01:02:04 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #5 on: July 20, 2013, 06:16:25 PM »
Quake State and Penzoil are high ash content oils, would not be my pick. Castrol 4t over Valvoline and others. Motul is very good oil if you can find it and probably best if you can find it after breakin.
Offline SKTP
« Reply #6 on: July 30, 2013, 01:03:40 PM »
So I am at the 100mile mark and going to do an oil change — going to try to find MOTUL 7100 20w50
Is synthetic OK at this point? Why not 10W40 like the book says?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline iron_worker
« Reply #7 on: July 30, 2013, 01:10:26 PM »
Run a proper motorcycle oil that has the additives necessary for your wet clutch etc. See if that helps. If not, it sounds like your cases are coming apart again...  :o
IW
« Reply #8 on: July 30, 2013, 04:42:08 PM »
Don't think different oil is going to help with only 100 miles on it since the rebuild, but at least you can do the tranny without taking the top end apart.
