Author Topic: 1977 CB750A Chain  (Read 2395 times)
Offline shar001
1977 CB750A Chain
« on: July 22, 2013, 07:13:02 PM »
I have recently purchased a drive chain for my bike, but the chain link gap is too small. basically it want stay on the sprocket. today I count the teeth count on F/R sprocket . they came up to 15T / 41T. The chain I bought was
530H Heavy Duty Chain - 110 Links.
Brand: BikeMaster
Chain Length: 110
Chain Type: 530
Color: Natural
Weight: 4.40
Height: 1.10
Length: 10.20
Volume: 0.02
could you please help me find the right chain.
thank you :-[
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
Re: 1977 CB750A Chain
« Reply #1 on: July 22, 2013, 10:24:11 PM »
I could be wrong......but I think my chain is a 630
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #2 on: July 23, 2013, 05:06:25 AM »
The 77/78 A bikes used 630 chain/sprockets.
The 76 A bikes used 530 chain/sprockets.
Usually, if your chain was shot/stretched then your sprockets are shot, too.  Did you give them a good inspection?  If your sprockets are OK, then buy 88 links of 630 chain.  If you sprockets are bad, then a chain will wear out quickly.
You do have the option of just buying 530 sprockets to use with your 530 chain.
« Last Edit: July 23, 2013, 05:13:02 AM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline dave the welder
  • dave the welder
« Reply #3 on: July 23, 2013, 06:46:56 AM »
my 77 came with a 630 chain this last spring I replaced it with a 530 set up.you have a bigger selection of gear ratios using the 530 chain
don't buy it build it
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #4 on: July 25, 2013, 06:47:58 AM »
The 630 chain might have made sense back in the day, but it's ridiculous now. A 530 O ring chain is a lot stronger than those old 630, and a lot lighter with less mechanical loss. I installed a 530  O ring with standard '76A sprockets on my '77 last year, and it's now done over 8,000 miles with very few adjustments required.
Stu
MCN DTF
Offline nick5446
« Reply #5 on: September 30, 2013, 11:21:19 AM »
Anyone know the length of chain required? How many links?
Thanks!
  • Moderator
« Reply #6 on: September 30, 2013, 03:43:14 PM »
Depends on the year.  The 77/78 models use 630 sprockets (15 front/42 rear) and chain (88 links).
The 76 models use 530 sprockets (17 front /48 rear) and chain (104 links).
Some convert the 77/78 models back to 530 sprockets/chain.
Today's 530 chain is stronger than the 630 chains of the past.
« Last Edit: September 30, 2013, 06:33:43 PM by kandrtech »
Offline nick5446
« Reply #7 on: September 30, 2013, 03:59:04 PM »
Ok cool, I ordered one with 112 links to be safe. Thanks!
Regarding strength, yeah I agree. It was funny to realize that the only bikes running 630 chains are drag bikes...I don't think my 750A has that kind of torque, but we'll see!
