Author Topic: Cb750 K3 carb question  (Read 876 times)
Offline pjwalsh
« on: July 24, 2013, 03:49:16 AM »
G'day all, as I was cleaning my carbs the other night I noticed 2 inlet/outlet pipes between the 2nd and third carb, nothing was attached to these so I'm curious to what they are for and if I need to do something with them?!
Thanks,
Pat
Re: Cb750 K3 carb question
« Reply #1 on: July 24, 2013, 04:15:36 AM »
I believe those are blind.
Probably technological shortcut, like making one casting form and using it for left side/right side caburetors with different plugs for each side.
« Reply #2 on: July 24, 2013, 06:04:36 AM »
They are a type of vent and yes there is a rubber hose around a foot long or so that should be attached to those.
« Last Edit: July 24, 2013, 07:01:52 AM by ekpent »
« Reply #3 on: July 24, 2013, 06:14:22 AM »
Story of my life, answering the question nobody asked  ;D
Offline iron_worker
« Reply #4 on: July 24, 2013, 06:59:42 AM »
Yep. They are the bowl vents. Not having a line on it probably won't really hurt it. I believe the purpose of the line is just to run the vent to a place a bit more protected from the weather (directly under the thank/seat).
IW
Offline bjbuchanan
« Reply #5 on: July 24, 2013, 11:08:10 AM »
I have been running to vent lines on it for over a year, all good. Lots of people don't bother. It is a personal preference thing, nothing comes of not using them in all types of weather
Offline pjwalsh
« Reply #6 on: July 24, 2013, 02:11:27 PM »
Excellent, thanks fellas! I don't think I will bother with attaching any hoses as it hasn't affected the running if it!
