Author Topic: Replacement Regulator/Rectifier CHEAP  (Read 192172 times)
Offline Queeg
  • insane fuel junkie
  • OY! with the poodles allready!
    • Queegs Problems
Re: Replacement Regulator/Rectifier CHEAP
« Reply #125 on: July 13, 2009, 11:45:40 AM »
    the colors are green, black, white.   looks just like all the pictures.
   as for where they go. i don't have a computer right now. and all i can do is read the forums on my blackberry.  which i don't get pictures on, unless theres a link :( and the pdf manuals are on my broken computer.
     kinda stuck.    thanks
  OK i think i figured it out, thanks for everyones input.  ill post some results in a few days when i get to ride again!
« Last Edit: July 13, 2009, 08:44:18 PM by Queeg »
guess who?
Offline Queeg
    • Queegs Problems
« Reply #126 on: July 14, 2009, 02:19:55 AM »
 OK so i hooked everything up did a few test. ran some extra fuses during my testing just in case.
  turned the key on a presto!! the magic smoke began. :( the new voltage regulator is burning up.
 i rechecked the wiring everything seems perfect.
 so now I'm back at square one. even my electronics savvy friend is stumped.
   ran the original voltage regulator and its fine.   made sure all wires wern't damaged after the first or 2ND meltdown.
guess who?
Offline Alan F.
« Reply #127 on: July 14, 2009, 07:00:16 AM »
don't forget to ground the case of your vr730.
Offline Queeg
    • Queegs Problems
« Reply #128 on: July 14, 2009, 12:08:25 PM »
  figured it all out at about 5 am PST.  the terminals on the regulators were marked differently then the schematic i was looking at. so i sat down with the bike, and regulator and traced it all out.
 ran it for about 5 minits and I'm very impressed how well it adjusts to load, engine speed and sudden changes.
   many thanks to everyone. and yes the case was grounded. :)
 i think ill take her for a ride in a while them pics for everyone to see.
  Queeg
guess who?
Offline Pinhead
  • 1979 CB652-ST
« Reply #129 on: July 14, 2009, 04:30:54 PM »
  Queeg
I thought I had the terminals the same on the schematic as on the regulator... In what order are your terminals?
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline cdoggy81
« Reply #130 on: July 14, 2009, 04:33:45 PM »
Post up some pics :)
Offline SkyPilot
« Reply #131 on: July 14, 2009, 04:58:27 PM »
Hey Pinhead, you mentioned a "cheap walmart battery" lasting 3 years.  Can you tell me the model number and price.  Would appreciate it, I need a battery!
Take Offs are Optional ... Landings are Mandatory!
Offline Alan F.
« Reply #132 on: July 14, 2009, 06:37:45 PM »
I looked a few weeks ago at walmart's m/c batteries, they seem to have one for a 750A, but not for K or F bikes.  If I remember correctly, the A-bike batteries were a little higher on the CCA's and were physically taller than the regular K/F bike batteries.
Does anyone know if they'll fit a K or F bike?
Spanner1 maybe?
« Last Edit: July 15, 2009, 05:58:38 AM by Alan F. »
Offline Queeg
    • Queegs Problems
« Reply #133 on: July 16, 2009, 02:20:50 AM »
  Queeg
i will double check rhis afternoos when i get up.  i was way tired and wanting the job done. i even for got to eat.
 and i will get some pics posted too, not mounted yet but its in there.
guess who?
1979 CB650
« Reply #134 on: July 17, 2009, 05:45:44 PM »
Hello, I'm a new member, but I've been looking at this forum for quite a long time. I have everything hooked up and the bike runs, but it still refuses to charge. I was wondering where the white and black wires coming from the rotor go to with the Ford regulator. It was rather confusing based on the original wiring diagram. Any help would be great, thanks.
Offline Alan F.
« Reply #135 on: July 17, 2009, 08:18:37 PM »
Do you mean the wires from the Field coil that connect to the 'F' terminal on the regulator and to Ground?
Offline Queeg
    • Queegs Problems
« Reply #136 on: July 18, 2009, 12:54:59 AM »
funny you ask. i tried to post the answer last night but my pics were to big.
  ill try to post pics again on Monday when i go to work!
 mine went like this.
  I = not used (dummy light)
  A=  wire from battery( used to monitor voltage) add this or it wont charge
  S= ignition switch (black from original voltage regulator)
  F= Field coil ( white from stock voltage regulator)
 hope this helps
guess who?
Offline Pinhead
  • 1979 CB652-ST
« Reply #137 on: July 18, 2009, 01:23:27 AM »
 hope this helps
Don't you have the "I" and "S" switched around?
I'm going to have to go out and double-check my wiring to make absolutely sure the diagram is correct.
Doug
:D
Offline Queeg
    • Queegs Problems
« Reply #138 on: July 18, 2009, 01:28:40 AM »
im totally looking at it right now......
 maybe they changed it  or maybe diffrent suppliers in diffren regions?
 gots me
guess who?
Offline Alan F.
« Reply #139 on: July 18, 2009, 08:21:22 AM »
I downloaded the diagram directly from the original post, I haven't gotten to the point on my bike where I can test for myself so I want to be sure the diagrams I have are correct.  Thanks for taking a second look P-H.
Does anyone think it would be cool to have a charging indicator light, like the original ford diagram had?
1979 CB650
« Reply #140 on: July 18, 2009, 08:44:38 AM »
I plugged the white wire from the Field Coil into the F terminal on the regulator and tried to ground the black wire. Unfortunately, this only created sparks when I tried to ground the regulator, and the 30 amp main fuse blew.
Offline Queeg
    • Queegs Problems
« Reply #141 on: July 19, 2009, 12:26:27 PM »
did you run a new wire from the positive battery terminal to the A terminal. this is necessary for the regulator to read the voltage and adjust!
guess who?
vbtiki750
« Reply #142 on: December 28, 2009, 05:55:26 PM »
I followed this thread and fried my wiring which may have been my own fault b/c I'm not an electronics wiz and am trying to make my own wire harness, i also had some questions if any one wants to shed some light on it
1. Does the wire coming from the two single phase rectifiers to battery + have a fuse in it, if so what size?
2. Does the vr730 regulator use a fuse battery wire also?
3. What is the best way to bypass the other two wires coming from the alternator unit, I believe they are the neutral safety and the oil light. If they arent what I thought they were (just for discription, they are the other two wire coming from the same plug as the 3 yellow wires and the green and white wire that go to the rectifiers and regulator) what are they?
Any input any at all is appreciated
Btw I have 76 cb750k
Offline Queeg
    • Queegs Problems
« Reply #143 on: December 28, 2009, 06:57:53 PM »
Yay I love this thread!!!!!
 Well ill tell u what! Its about time I took some pics so I'm gonna do it tomarrow @ the shop!
 NOW I'm going to do this off memory so bear with me.
No you don't need to fuse the yellow wires
A fuse on the lead from the batter to the vr730 is a good idea but I don't have one and I just remembered my bike is still in orange after it killed itself Christmas eve! Hmm ok offtrack
So fuse on voltage wire yes good idea, but I don't and have had no problems yet!
 Kinda hard to remember this all when I can't see everything on my blackberry!
If you have any more question let me know ill be on my desk top in a few, I'm finishing up here in my shed.
 OK now on the desktop.
the other 2 wires are oil light. that's the one coming from the 1" approx round thing with a hex/Phillips bolt. the other should be the neutral light(not 100% sure)
 the wire from the rectifiers i believe does go thru the fuse block 15amp main.
i really wish i had my bike here to look now.
but the other 2 from the oil and neutral lights should be in the same connector. but maybe yours is diffrent.
and i had the side off a 550 last night so I'm trying not to use that as a reference too much
« Last Edit: December 28, 2009, 07:26:52 PM by Queeg »
guess who?
vbtiki750
« Reply #144 on: December 28, 2009, 08:03:56 PM »
thanx  queeg, I will run a fuse on the regulator if its not fried. do you know a good way to test the vr730 to see if it fried? And as far as the lights I could just wire nut those off and not see any problems right?  If you ever get around to it some pics of this setup would help, I dont know why my wiring job didnt do the trick but its probably right in front of my face. Thanx  for your input.
Offline Queeg
    • Queegs Problems
« Reply #145 on: December 28, 2009, 09:40:28 PM »
i had a test meter on the battery as i did the start up. if its fried it wont work at all. or have really low readings.
at idle i was getting 12.4v
and at 5k rpm i was like 13.8v
i did test higher but i dont remember what i got, like 14.2 at 7+k rpm.
 after that it just worked. did the same on mt g/f's bike before i started paonting it.
it ran a little higher but i also got a heavy duty version of the vr730. was also like 4 dollars cheaper at the time.  same case size . and everything. i didnt gut it yet as ill do that when i put the electrical back into the bike.
guess who?
Offline harald
  • Sandcast69
« Reply #146 on: January 14, 2010, 02:39:13 PM »
I found this in CB 750 Club in Germany.
Unseren bewährten elektronischen Regler im Originalgehäuse gibt es im Austausch, d.h. alter, gereinigter Regler wird uns zugesandt. Dieser wird von uns umgebaut und jeder bekommt sein Reglergehäuse mit der Elektronik retour, Preis 44 € plus Versandkoste
Costs 44 euro
and this which looks the same----Elektronischer Laderegler für CB 750 Four*
Kein Auskochen mehr
Voller Ladestrom schon bei 2000 U/min
Maximale Ladespannung 13,9 V für Gelbatterien und Reinbleiakkus dringend erforderlich !!
Original Optik im alten orginalen Gehäuse eingegossen, daher absolut Feuchtesicher !!
Preis 50 € (im Tausch gegen alten Regler) zzgl. Versand.----------------------------------------------------------------------------
« Last Edit: January 14, 2010, 02:49:02 PM by harald »
Offline GammaFlat
« Reply #147 on: January 14, 2010, 09:15:48 PM »
Those are intriguing.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #148 on: January 14, 2010, 09:27:35 PM »
Are the top and bottom pics both voltage regulators?
They look different.
Offline Fritz
« Reply #149 on: January 14, 2010, 10:44:34 PM »
Hi!
The electronic regulator replacements are done by two different members of a German "CB Four Club":
http://www.cbfourclub.de/
Use the "Börse" link on the top and then "Zubehör" on the left side. They both ask you to send in your original regulator and exchange the relay with their electronics. Don't know if they would ship overseas but maybe it's useful as an inspiration.
1976 CB550F
