Author Topic: Replacement Regulator/Rectifier CHEAP  (Read 194293 times)
Offline Pwfyrcat1
  • What I'm doing when it's warm
Re: Replacement Regulator/Rectifier CHEAP
« Reply #75 on: September 11, 2008, 02:30:00 PM »
And me having to do the same to a 750.  I will have to give it a go ::)
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline Pwfyrcat1
« Reply #76 on: September 11, 2008, 02:58:04 PM »
So when I am looking for the rectifier, what combination of amp/volts should I look for?
I am going to need to read this thread several times...
1992 Yamaha TDM 850
tatergirl77
« Reply #77 on: September 12, 2008, 06:54:28 AM »
 ;D ;D ;D BAD A$$!!!
i'm just dropping back in to say that this system works perfectly now! got everything hooked up and bolted down, and covered the terminals with a coat of white lithium grease, and the charging prob is a thing of the past. at 6k rms it topped out @ 13.76v .. so it charges the battery like it should but doesn't overload AT ALL. Than you guys so much for the extra help  ;D
now everything works right, i get to do the fun stuff (paint & new turn signal lights, ect) WOOHOOO!
Offline Pwfyrcat1
1992 Yamaha TDM 850
Sherman
« Reply #80 on: September 18, 2008, 01:09:41 PM »
I have done a similar project. I don't have pictures but I have the diagram I used to do the project. I used the cheap and available parts from the Delco 10SI alternators. This circuit has the advantage that it uses only a small amount of battery voltage to get polarized and then it is completely self producing with no load to the battery.
Click thumbnail for full sized picture.
My bike started off with a shorted rotor and I had to buy a replacement. It charges better than the factory one now.
One should always check the rotor resistance with a good digital meter and make sure the resistance is about 5 ohms.
Offline Pwfyrcat1
« Reply #81 on: September 18, 2008, 03:07:47 PM »
Man these things are tiny! :o
Now lets see if I can't get them hooked up!
1992 Yamaha TDM 850
ev0lution7
« Reply #82 on: September 18, 2008, 03:10:42 PM »
mine worked great i love it charges my battery perfect.
Offline Pwfyrcat1
« Reply #83 on: September 18, 2008, 04:35:40 PM »
Just curious, can a heatsink be any type of metal?  Though I am probably going to go to radio shack and pick one up tonight.
1992 Yamaha TDM 850
ev0lution7
« Reply #84 on: September 18, 2008, 04:37:26 PM »
aluminium is best but i made mine out of aluminium stock that i bent in a bench vice and the cut some slots for cooling in it and used heatsink paste that i got from radio shack to attatch it also i painted it to kinda match the factory piece.
Offline Pwfyrcat1
« Reply #85 on: September 18, 2008, 04:52:12 PM »
ev0 7, thx
I have some flat aluminum stock.  Though I don't have the paste, I still have to go to RS
Though, if it's just silicon, won't any black silicon do?
« Last Edit: September 18, 2008, 05:08:56 PM by Pwfyrcat1 »
1992 Yamaha TDM 850
ev0lution7
« Reply #86 on: September 18, 2008, 05:16:48 PM »
it needs to stay fluid not adheasive.... believe me i work on computers its totally different stuff....
Offline Pwfyrcat1
« Reply #87 on: September 18, 2008, 07:26:11 PM »
TwoTired,
Since I am using the 5 prong unit, do I only need one?
1992 Yamaha TDM 850
ev0lution7
« Reply #88 on: September 19, 2008, 08:19:32 AM »
yes
3 wires goto the yellow
1 wires goes to the red
1wires goes to the black
Offline Pwfyrcat1
« Reply #89 on: September 19, 2008, 01:26:44 PM »
So where or to what, is the heatsink compound applied?
1992 Yamaha TDM 850
Offline Pwfyrcat1
« Reply #90 on: September 19, 2008, 03:36:40 PM »
So this is what i have so far...
I used the wires from the old  rectifier.  Over at hondachopper.com there are wiring instructions for the 750, that utilizes the 750 stock wiring harness, prongs and all.  Again, to avoid paying out large quantity of money for my near ZRO project.
Take a look and let me know if I need to switch the red and green wires +/-.
The white wire I believe comes from the regulator and will be attached with the other five wires to the six prongs that come off of the engine.
It's in their garage section of Santee wiring instructions
And thanks for all the help
1992 Yamaha TDM 850
Offline Pwfyrcat1
« Reply #91 on: September 20, 2008, 12:07:29 PM »
does anyone have an answer for my last two posts?
1992 Yamaha TDM 850
Offline Pwfyrcat1
« Reply #92 on: September 20, 2008, 02:52:34 PM »
Just in case it's too much work, I found this info over at the Metric Underground.
http://hondarectifiers.com/
1992 Yamaha TDM 850
Sherman
« Reply #93 on: September 20, 2008, 04:32:30 PM »
I uploaded a picture layout of the schematic posted earlier. It might answer some of the questions about heatsink compound and such.
Sherman's Voltage Regulator Project
Offline mikethejeepguy
« Reply #94 on: September 22, 2008, 06:27:48 AM »
This is an awesome post. I just read all 7 pages and am sold. I've been having charging  troubles too and got left on the side of the road on the weekend with a dead battery after hitting apparently one too many stop signs and red lights. Unfortunately most of my riding is city riding. So the way I understand it, there are two ways of setting up the rectifiers. You only need 1 Three phase rectifier, or 2 connecte 1 phase rectifiers right? Can anyone recommend a good place in Toronto/Mississauga/Ontario to purchase these? Much thanks.
'76 Honda CB550F, Dana-S'd, Uni filtered, HID'd, LED'd, and mildly cafe'd with many plans still.
ev0lution7
« Reply #95 on: September 23, 2008, 11:47:12 AM »
http://www.oregonmotorcycleparts.com/rectifiers3p.html
this guy sells a completed product same thing though but 2x more expensive than the one i built he also has NEW connectors if you want to RENEW your plug for the harness i looked at mine (which melted) and i thought it was a good upgrade and i also bought a new plug (6pin) for my fuse box as it was badly coroded :( so overall its a good upgrade and can really help out poor charging systems !
just so you know i also had the option to put in a COMBO unit i didnt do that for 2 reason:
1. it doesnt apear to be stock
2. like a combo DVD/VCR if one or the other or both go out i have to replace the UNIT! if my combo reg/recifier goes out or just one of them i have to replace the whole thing (sometimes $100) so i chose to go with a seperate unit because if my recifier fails then i just replace the little rec for $14 or if my regulator fails (its a solid state unit from oregonmotorcyclesparts and has a lifetime warr) then i just replace that seperate! its much simplier then and it APPEARS STOCK!
« Last Edit: September 23, 2008, 11:51:06 AM by ev0lution7 »
« Reply #96 on: September 23, 2008, 08:56:10 PM »
You make a realy good point about the failure and replacement AND a good analogy too!  ;D  I would like to go the same way as you did. The regulator from Oregon, and the rectifier I can build. I have an old rectifier that I can use the harness & cartridge from. Do you remember where you got your rectifier from? and which unit?
ev0lution7
« Reply #97 on: September 25, 2008, 08:06:55 PM »
if you look back a few pages i gave the item i ordered its from Digikey and its a 3 phase 35A recitifier
DONT FORGET to replace the harness plugs on the chargin system like the one from the stator on the engine and the one for the rectifier and the one on the fuse box those are HUGE spots for charging loss!
Offline JP74
  • "i'll be at the garage"
  • always more work do...
« Reply #98 on: October 13, 2008, 10:15:51 AM »
my regulator is shot, but my rectifier seems to be ok, i haven't seen any posts of people using  the stock rectifier with the mid 70's pickup regulator (autozone PN VR730)... any reason why using the new regulator with the stock rec would be a problem?
76-cb750k, 75-cb360T, 71-cb750k,
73-cb750 AMEN hardtail,
78-750k roller..cl350..cl450. kz400,gs750.  maybe more
Offline JP74
« Reply #99 on: October 14, 2008, 08:59:48 AM »
i picked up the autozone VR730 regulator, however there are no markings on it or info... not sure what to wire what to, looks just like the regulator in the original post. any help or photo would be amazing. thanks.
