Author Topic: CB350 twin top-end gasket set.. which one?  (Read 1264 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: July 26, 2013, 10:02:17 AM »
Gonna have to pull the head on this 350 I've been working on to fix a stripped spark plug hole (I didn't do it!!). Has anyone had success with the Versah top-end gasket set? Does it come with everything you need?
Offline toytuff
  • "watching the pinheads"
Re: CB350 twin top-end gasket set.. which one?
« Reply #1 on: July 26, 2013, 12:21:22 PM »
Others might have suggestions but I always use Honda gaskets when I can.
 Maybe the kit but a good head gasket from Honda? Just me.
tt
Offline grcamna2
« Reply #2 on: July 28, 2013, 12:16:41 PM »
Those Vesrah gasket kits are just as good as O.E. Honda gaskets..,just a little bit cheaper.I purchased a few yellow colored background Vesrah top end gasket sets on Ebay for my CB350 twin,they're good stuff but the head gaskets will only work w/ bores up to .75mm over.I bored mine to 1.00mm over & had to get a head gasket from Bore Tech.
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: July 28, 2013, 01:07:51 PM »
I have used several Vesrah kits and not had any problem.  The kit will not have any seals...Larry
