Author Topic: 72 CB 750 brake line pipe question  (Read 1750 times)
Offline thomellis
« on: July 28, 2013, 05:09:24 PM »
Hey Guys,
I need to get a new brake line pipe for my bike, and I'm finding that there are 2 different part numbers:
45128-300-010
and
45128-341-670
From what I can  tell, the bend is slightly different between the two, but I don't have an original to compare to, so I'm not sure which I need, or if it even matters?  Thought I'd check if anyone happened to know?
Thanks!
Offline Viktor.J
  • Breaking in the forum
Re: 72 CB 750 brake line pipe question
« Reply #1 on: July 29, 2013, 02:58:44 AM »
Where are you finding this ? what bike is it ? what year is it ?
Watch the part list manual, take the partlist number and you'll be pleased.
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline Dream750
« Reply #2 on: July 29, 2013, 08:51:38 AM »
I need to get a new brake line pipe for my bike, and I'm finding that there are 2 different part numbers: 45128-300-010 and 45128-341-670
Actually, both brake line part numbers you posted are correct for a 750 K2. The difference depends on your frame number as there was a brake caliper bracket & pin design change during K2 production.
45128-300-010 is used on the 750 K0/K1 and K2 ending at frame number: CB750-2093730
45128-341-670 is used on frame number beginning with CB750-2093731 and continues until the end of K6 production.
In other words ...
If you have the earlier style caliper bracket & pin: (1 and 2 in the diagram below), then use: 45128-300-010
If you have the later style caliper bracket & pin: (1-1 and 2-1 in the diagram below), then use: 45128-341-670
« Reply #3 on: July 29, 2013, 09:32:59 AM »
Usually when you see those part numbers 300 is for early bikes,pre 72 and 341 for later bikes or like you a model year change during production.
Offline thomellis
« Reply #4 on: July 29, 2013, 10:01:29 AM »
Awesome thanks guys.
Appreciate the detailed response Dream, that's exactly what I needed.  I definitely have the old bracket (1 and 2 in the diagram), really appreciate pointing that out, now I can order without worry.
Thanks ekpent, I did not know that about the part numbers.  That should be helpful in the future.
Thanks again guys!
