Author Topic: drouin rebuild  (Read 3404 times)
Offline superchargerheaven
drouin rebuild
« on: July 30, 2013, 02:07:53 pm »
If anybody has one apart or pictures of when they took it apart ,i could sure use for reference.
I have one of these kits but it has been abused and ill have to machine a few parts .
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
95 zx6r landspeed racer
hand built electric bike in progress.
Offline KayOne
Re: drouin rebuild
« Reply #1 on: August 01, 2013, 07:55:04 pm »
Contact Gilles at Edmonton Motorcycle salvage.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
Re: drouin rebuild
« Reply #2 on: August 02, 2013, 08:05:08 am »
Thank you...much appreciated.This thing has been chewed up doing dirt drags in the past .Belts wont track, bearings wander,all fixable.
May have to weld up main pulley shaft and machine it down ,all fun as hell in the end .
If anybody would like me to post the rebuild let me know,i have loads of pics.
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
Re: drouin rebuild
« Reply #3 on: August 02, 2013, 10:40:14 am »
We see very little of supercharger stuff here. More turbo stuff. Please do a write-up.
Re: drouin rebuild
« Reply #4 on: August 02, 2013, 09:50:14 pm »
I would like to see those pics, too!
Offline ivanhoew
Re: drouin rebuild
« Reply #5 on: August 03, 2013, 01:04:44 am »
wot he said ^^^^
just do it .
Offline FuZZie
Re: drouin rebuild
« Reply #6 on: August 03, 2013, 04:59:04 pm »
I'd like to see it too!
Offline fang
    • Food Renegade
Re: drouin rebuild
« Reply #7 on: August 04, 2013, 03:50:50 pm »
Me Three!
Download Nervous Norvus' "The Fang"  HERE.
Tired of eating CRAP!
Re: drouin rebuild
« Reply #8 on: August 06, 2013, 09:00:58 am »
Ok then well .......here is the whole kit i have .I traded it for my gt 750 front 4leading drum hub and cables .
This supercharger is good in theory but lacks a bit in execution.It is what it is (old)and if it flows more into my engine even just a bit ill be happy
For starters the edges don't line up Ill file them to match after i fix the numerous problems .....
So from what i hear the drouin would chew up bearings (was this because the proper ones weren't being used?)and it would sieze and from what i was told stall the motor right then and there.
you can see in the pictures where the pulleys hit and walked into the compressor housing.
the main shaft has been bent and chewed up (no i did not put the epoxy on the shaft)
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
Re: drouin rebuild
« Reply #9 on: August 06, 2013, 09:33:45 am »
So the first thing i did it try to get the flat belt to track correctly.......Holy crap i just about went into my boxes and fetched out a turbo instead.
So tracking on 2 pulleys is hard enough with worn shafts and pully surfaces,not to mention questioable bearings.
First off was to flip spacers around to make sure the pulleys were centered .......Great, did it track ,yes alittle better.
(a little tid bit on flat belts one pulley only should be crowned not two)both of mine were crowned.
But to make things worse lets add a third pulley ,the tensioner.especially one with a worn to poop seating surface (on the shaft and in the housing)once tensioned the belts on this thing couldn't be tamed with out 45 min of adjusting the smallest of small movements.
Then it would track for about 30 seconds and the belt would slowly start to move in the direction of the housing and try to eat itself.
The only thing to do now is put things on a dial gauge and and then true everything up :)
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
Re: drouin rebuild
« Reply #10 on: August 07, 2013, 08:21:41 am »
So the large flat belt pulley was 7 thou out of round.......fixed
and the shaft it bolts to was out as you can see int the pics ,will most likely build a new one as this one has been through alot.
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
Re: drouin rebuild
« Reply #11 on: August 09, 2013, 07:51:31 am »
I removed the epoxy from the shaft to see how bad things were, was not expecting this bad.
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
Re: drouin rebuild
« Reply #12 on: August 09, 2013, 08:13:42 am »
Looks like cutting torch marks almost.  In 2. Hours you can make a new shaft..
Re: drouin rebuild
« Reply #13 on: August 09, 2013, 09:56:44 am »
Would take me more than that.hahah i may just weld up and re machine.
hmmm i may do both ,the reverse thead will be the hard part.
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
Offline SF
  • I burn gas very well
Re: drouin rebuild
« Reply #14 on: August 09, 2013, 10:09:03 am »
very cool
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Re: drouin rebuild
« Reply #15 on: August 09, 2013, 10:52:26 am »
Reverse thread is easy..other than the woodruff key,the rest is easy to machine.
 Its. Outlived its useful life..
Re: drouin rebuild
« Reply #16 on: August 09, 2013, 12:50:13 pm »
Out lived it's useful life......haha hey now ,so has the cb 750 but people keep fixin them up hahahahah ,ill do both ,im leaving to pick up the chunk o metal right now.Wish me luck... don't know if my smitthy lathe can deal with all that cutting  :D
88 gsxr 7/11
82 katana 750
3x gt750
85 gpz900r
74 h1 500
89 vmax
xs 650 chop
Re: drouin rebuild
« Reply #17 on: August 09, 2013, 02:41:12 pm »
Too bad you aren't closer, i could rough it out for reasonable....good luck..
Offline BLUE71TURBO
Re: drouin rebuild
« Reply #18 on: August 09, 2013, 11:33:57 pm »
 Take the bolt to a special machinist !   ;)   Don't cheap out when it comes to a very important part. Remember that supercharger is right next to your left leg and nuts.  When superchargers and turbos blow up it's like a fragmental grenade going off.   :o
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
Re: drouin rebuild
« Reply #19 on: August 18, 2013, 10:57:59 am »
Cool thread, keep it coming.  ;)
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline shpwrk
Re: drouin rebuild
« Reply #20 on: October 26, 2014, 03:16:52 am »
I have just completely rebuilt a Drouin. Have all the bearing numbers if you need them. Everything in blower is running true. The high speed bearings are expensive. I spent just shy of 700 for bearings alone. I have everything polished looks good and mechanical is done right. I have everything for a bolt on. Could be done in a few hours. Could use the mechanical FI it came with or use carb. If I were  to run it I would use a carb.  The blower is on ebay. Selling because a RC big engine just came  my way. This blower was used very little before I rebuilt it. I have all receipts additional belts and install instructions. I am confident that this blower will run as it should and add 50% more power to your stock Honda 750. Spoke to some guys early on in the project who ran these in the day. I have been told that these were able to leave the Z1 in the dust. These are just flat out cool. Hearing the wind of a blower at a bike show is beyond cool
Pete Caroselli
Offline Bill/BentON Racing
    • BentON Racing
Re: drouin rebuild
« Reply #21 on: October 26, 2014, 05:32:41 am »
Mine was good enough to outrun 78 Z1R stock. They were first production bike to break into the 11's..Cycle Magazine 11.95. Beat him stock, next week he had one tooth less and a RC pipe..he won!
Drouin flat belt to run straight and proper fuel delivery were my biggest challenges. G' luck Bill ;D
8-12 lbs boost will help! Also eats up ring life. Mine was 135 across the board when I took it off, 175ish before! But oh what fun, nice sound too.
BentON Racing Website
BentON Racing Facebook
Offline BPellerine
Re: drouin rebuild
« Reply #22 on: October 26, 2014, 04:08:54 pm »
ok now lets see the big rc motor!bill
1978 CB 750K ard and webers
another anfob
    • BentON Racing
Re: drouin rebuild
« Reply #23 on: October 26, 2014, 04:38:31 pm »
Stay tuned! ;D
