Author Topic: '74 CB450 Refurbishment Thread (Brownie)  (Read 11312 times)
Re: '74 CB450 Refurbishment Thread (Brownie)
« Reply #25 on: August 15, 2013, 08:13:24 PM »
I've been seeing these reproductions and they looks very good. I like the stock look. Great price, too.
http://www.davidsilverspares.co.uk/CB450K7-SUPER-SPORT-1974-USA/part_123891/
No no no.  If you are going to order a MC, go here. I doubt I will ever rebuild a MC again.
http://www.davidsilverspares.com/CB450K5-SUPER-SPORT-1972-USA/part_123889/
$44 for a new m/c?  You're right Steve, hardly worth rebuilding one at that  price...Larry
Plus another may be $50 for shipping to US?
DSS has a US location in PA now....
fendersrule
« Reply #26 on: August 15, 2013, 08:29:52 PM »
I've emailed to see how much shipping is.
Ther fork gaiters (OEM) are good priced too. Cb450 used the same as CB750.
I wonder what the difference is between cb450 bars and cb500.
EDIT: Difference is that the CB500 bars look to square. Never-mind.
« Last Edit: August 15, 2013, 09:02:20 PM by fendersrule »
fendersrule
« Reply #27 on: August 17, 2013, 02:45:48 PM »
Had a very lucky day today.
Ordered:
Tachometer
Handlebars
Master cylinder (used)
Fork Gaiters
BT-45 front and rear tires
bearings/seals for front and rear tires
Forks are on the way
I think part hunting for this bike is now over.
fendersrule
« Reply #28 on: August 22, 2013, 09:05:48 PM »
Rebuild front end
* New seals
* Washed out the guts with mineral spirits
* ATF transmission oil
* New gators
* New fork tubes
She's starting to look like a real CB450 again.
fendersrule
« Reply #29 on: September 07, 2013, 07:51:30 PM »
She's been hard at work "cleaning" stuff.
*Ordered 1972 CB750 handlebars...we are going to test fit these as they are close to CB450 bars, although a bit shorter on the rise.
*Ordered Master Cylinder from David Silver Spares.
Still looking for a tachometer.
This is going to be a very nice bike. The compression is only decent, but it's going to be a head snapper compared to her little CB125.
« Last Edit: September 07, 2013, 07:53:41 PM by fendersrule »
fendersrule
« Reply #30 on: September 21, 2013, 07:51:36 PM »
Finished Brownie today. Gorgeous bike. Looks better than my CB750. There are some remaining issues:
1) Repair clutch cable notch on actuator arm (I think this is what it's called). I tightened the clutch adjustment screw too much and it came in contact with the chain. Gotta find someone who can repair this because it involves riveting. Any ideas?
2) Get new front turn signals. This have been modified. There should only be one wire coming out of them, but there's two. Figured i'd start fresh so she can get some functional turn signals.
3) Rebuild the carbs. My simple cleaning wasn't enough. The engine bogs at higher RPMs. Off to the pops for this task.
4) Replace right side engine gasket. Big-time leak!
5) Refurbish tachometer.
Other than that, progress is going well. Here's some pics for your viewing pleasure.
« Last Edit: September 21, 2013, 08:24:34 PM by fendersrule »
« Reply #31 on: September 21, 2013, 09:24:03 PM »
sich22 on ebay has. A new i think tach for 100 bux..
fendersrule
« Reply #32 on: September 21, 2013, 09:57:03 PM »
Nice tach, but not a '73-'74 because it has the indicator lights built in...
« Reply #33 on: September 21, 2013, 10:49:25 PM »
Well your front brake does not look correct either.. Not sure how picky you are..
Offline tbpmusic
« Reply #34 on: September 22, 2013, 07:17:03 AM »
What looks wrong about it to you??
Bill Lane
fendersrule
« Reply #35 on: September 23, 2013, 01:35:24 PM »
The only thing that isn't stock is the handlebars. Those are repro 1971 CB750k Bars, which look perfect on this bike IMO (drilled holes and everything). Same width as the stock bars, but less pullback and less rise. I've always found the CB450 bars to be on the tall side. I may have to do the same bars on my build.
Offline hoodellyhoo
  • CB350F
« Reply #36 on: September 23, 2013, 05:20:27 PM »
You sure about that? I think 74 is when the cb750 first got running lights in the front so I would assume the 450 had them as well..
fendersrule
« Reply #37 on: September 23, 2013, 07:40:58 PM »
Not too sure. I did take a search on eBay and found that most, if not all the '74 CB450 turn signal had one wire exiting them...
Offline MoMo
  • Ride like you're invisible
« Reply #38 on: September 23, 2013, 07:45:37 PM »
I think it was 75 when the running light became mandatory.  But my memory can be foggy ::)...Larry
Offline hoodellyhoo
  • CB350F
« Reply #39 on: September 24, 2013, 06:39:02 PM »
I just did a little looking at the fiches and they show one wire for 74. I thought I remembered that some bikes got the "beehive" turnsignals with running lights. I know that the new Emgo beehive signals have two wires.
fendersrule
« Reply #40 on: November 10, 2013, 07:21:03 PM »
* Replaced Fuel Hoses
* Replaced Points/Condenser. Set timing.
* Reset floats
* Installed fuel Tank cap gasket
* Sanded front brake pads
* Compression shows 150/165. Pretty much good to go.
Fellas, I think Brownie is complete.
« Last Edit: November 20, 2013, 09:29:00 PM by fendersrule »
fendersrule
« Reply #41 on: December 27, 2013, 04:42:01 PM »
Just finished the final tuning. I put fuel stabilizer in the gas tank and I'm going to winterize it.
CB450K7
1) Replaced Diatchii points with slightly used Honda OEM points plate assembly. Diatchii condenser installed (Honda one was bad)
2) Rebuilt carburators. Cleaned twice. OEM parts.
3) Air/mix screw set by exhaust analyzer
4) Static timing set spot on.
5) Cam chain tensioner set
6) Valves set exactly to .002"
7) New OEM NGK plugs. New NGK plug caps.
There's nothing else to tune.
Bill, sound good to you?
« Last Edit: December 27, 2013, 04:44:20 PM by fendersrule »
Offline Carver
« Reply #42 on: December 27, 2013, 05:48:42 PM »
what kind of mirrors are those? my 450 frame fell over and smashed the mirrors and i want something less antenna like than the ones i had.
Cb 750 k3
Cb 450 dohc k4
Offline nccb
  • 1974 CB750 Four
« Reply #43 on: January 03, 2014, 09:34:36 AM »
you left your blinker on  ;)
fendersrule
« Reply #44 on: January 03, 2014, 09:40:47 AM »
I sure did. :)
At 18F, I probably made some other mistakes too.  :o
Carver: Those are aftermarket stock replacement mirrors.
fendersrule
« Reply #45 on: February 23, 2014, 07:34:22 PM »
The saddle has been filled by the real owner...:)
fendersrule
« Reply #46 on: February 23, 2014, 08:34:36 PM »
Posting a video here soon
CB750 Hunts a CB450
Steve-o will like this.
« Last Edit: February 23, 2014, 09:30:11 PM by fendersrule »
« Reply #47 on: February 24, 2014, 06:15:15 AM »
Sorry, not so much. I don't like City riding.  This is better...
http://m.youtube.com/watch?v=wmNda8rOdds
Offline nccb
  • 1974 CB750 Four
« Reply #48 on: February 24, 2014, 06:54:21 AM »
the bike looks pretty sweet man.  I like the way the twins look.
fendersrule
« Reply #49 on: February 24, 2014, 10:00:22 AM »
Just thought you'd like to see the CB750 in action. I had 20 minutes of boring riding footage before showing similar environments to the link you posted. We've got lots of good roads and rides up here in ID. There was about 80GB of video that didn't really have anything exciting.
