Author Topic: A couple engine questions  (Read 1019 times)
Offline Fish
« on: August 10, 2006, 08:46:05 AM »
Hello all,
I have started polishing the aluminum crankcase covers on my '75 cb550 and would like to take them off to do a more thorough job.  My question is, if I do take them off, will I need to have new gaskets or anything like that to put them back on, or just bolt them on?
My second question is about my cam chain.  I have searched different threads and have already posted about the level of cam chain noise.  The answers I have seen range from "it's just the nature of these old engines, don't worry about it" and "it could be a serious problem and it needs to be addressed".  I normally wouldn't be worried about it if I thought my tensioner was working properly, but it doesn't move at all when I loosen the locknut.  In fact, I can't even turn the tension screw with a screwdriver(clock-wise or counter, same thing).  Can anyone tell me what might be the problem here and what it might take to get the tensioner working?
Thanks,
- Chad
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: A couple engine questions
« Reply #1 on: August 10, 2006, 09:06:13 AM »
What do you mean by "crankcase covers"?
You can take off the points cover (which is chrome anyway - with a cork gasket), the alternator cover (but the field coils come with it), and the gearbox/sprocket cover without needing gaskets.
If you take off the clutch cover, make sure the bike is leant over as the oil will come out!
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Fish
« Reply #2 on: August 10, 2006, 11:33:36 AM »
Great, thanks for the info.  I was just looking at diagrams and noticed that the right crankcase cover has a gasket behind it.  The left side though doesn't have one.  Maybe I'll start polishing on that side.
- Chad
