If you've replaced your regulator/rectifier, rotor, and stator, there's not really much else in the charging system besdies connections.
On the R/R there are two connectors. One has 3 wires and the other has 5 wires. In the 5-wire connector, the bottom three (should be all yellow) are the output wires from your three-phase alternator (hence the three wires). The top two wires are the field wires. Somehow disconnect those two wires from your regulator and hook 12v straight to them (on the alternator side, not the regulator side). With those two wires connected, rev the engine and check battery voltage. If your voltage doesn't go up, you've got a problem with your rotor or stator. If it does go up, I would suspect the regulator.
