Wow lots of debate here over which method is acceptable. I hope you all can see why Ive tried both.
Well, good news! I have , for the fourth time, done the static cam tension adjustment and finally the noise is gone.
I dont think that was my problem however. When making the adjusrment last time I noticed some wear on the underside of one of the tappet covers from #1 cylinder. Looks like the rocker arm was contacting it. Maybe I had it done up too tight? Is it that tight a fit between the tappet cover and tappet?
Either way, thanks for all of the input. I think I will stick with the static method as it just seems safer and really is minimally more work. Now if that rain would just quit...
