Author Topic: PLEASE HELP -- Clutch Cable  (Read 1952 times)
Offline macisaguy
  • Yeah, I'm New
« on: August 09, 2013, 06:21:46 PM »
Okay.  Feel free to call me names, laugh, and generally make fun of me for buying a vintage bike when I'm the least mechanically inclined guy out there.  (I am trying to learn.  Really and truly.)
I cannot for the life of me figure out this effing clutch cable.  I'm putting a new one on my '78 CB550.  OEM part, so it should be right length and everything.  It seems though that there's not enough length/slack in the cable to get it into the arm down at the bottom.  It's just so short.  Even if I did get it fitted, the arm would stay up as there is NO slack.
I have combed through my Clymers, owner's manual, and my Honda Shop Manual.  I have gone through this thread and read numerous posts, watched videos and am now resorting to yelling and pulling my hair out.  I'm confused, angry, but mostly frustrated.
Here are photos of the setup.  Does anyone have ANY IDEA what I'm missing here???  Why isn't this cable long enough?  Is it just that the cable's too short and either I ordered the wrong part or was sent the wrong one (the former being far more likely)???
Please help.
« Last Edit: August 09, 2013, 06:23:46 PM by macisaguy »
Turns out bikes don't come with babes.  Apparently I was misinformed.
Offline Reganator
  • Just another guy with a CB750 kinda cafe.
Re: PLEASE HELP -- Clutch Cable
« Reply #1 on: August 09, 2013, 06:31:35 PM »
This seems like an obvious question that went unanswered... I'd assume you have the old cable available to compare lengths?
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
     Stock needle and settings.
My-neighbors-love-me-Kerker 4 into 1
Stock airbox
The best way to make a small fortune on the stock market is to start out with a large fortune.  Trust me, I'm an actuary.
Offline macisaguy
  • Yeah, I'm New
« Reply #2 on: August 09, 2013, 06:45:11 PM »
Yes...and this one is shorter.  But I don't think the one I took off was stock, as this bike had some crazy high chopper bars on it.  So it needed to be longer.  (It could have been stock...but I doubt it as the bars and forks had both been swapped out and were longer and higher than stock parts.)
But it simply may be this cable is too short and I'm over complicating things.  Just needed to see if I was missing something as I'm all alone on this, and needed the opinion of folks who know what they're doing.
Offline Reganator
« Reply #3 on: August 09, 2013, 06:49:37 PM »
I can't speculate on the cable you removed, but assuming you've got the routing correct I'd guess you got the wrong cable somehow.  It isn't as if that is something which has never happened.
Frankenbike CB750:
71 K1 Frame
72 K2 Engine
75 F0 Carbs:
     #40 slow jets
     #105 Main Jets
Stock airbox
Offline reddyvv
« Reply #4 on: August 09, 2013, 07:47:14 PM »
First, check that you have the clutch arm on the case adjusted so the notch on the arm lines up with the notch on the case. Also make sure the adjuster at the lever end is fully screwed in. Next put the cable end into the arm first and then pull it into the adjuster bracket.
« Last Edit: August 09, 2013, 07:49:40 PM by reddyvv »
Offline bjbuchanan
« Reply #5 on: August 09, 2013, 08:05:10 PM »
I went on dime city and pulled up your bike and the page I'm linking has the rough stock length of the cable. Granted it is a motion pro cable which is never the real length but is functionally long/short enough for the bike
52.5" long, motion pro is usually just a little too long
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-cables-honda-cj360-cb360-cb550-cb750-clutch-cable-02-0005.html
Offline uksparky
  • Track days
« Reply #6 on: August 09, 2013, 10:28:00 PM »
Ok your problem is the cable where it goes through the bracket, bolted to the rear mount...the cable nut has to be flush with the bracket..tap it through until it stops at the cable nut....the other end runs under the guages to the clutch lever
« Last Edit: August 09, 2013, 10:35:08 PM by uksparky »
Present bike 1982 900C Custom
Offline macisaguy
  • Yeah, I'm New
« Reply #7 on: August 13, 2013, 10:39:00 AM »
Thank you guys so much.  Finally got it sorted out.  uksparky was right about that adjuster nut not being flush.  (Turns out it was too big for the bracket.  Took it off, put the original adjuster nut on the new cable.  BAM.  Major success.  Thank you all again for the help.
