Author Topic: I have been set free! no more pods!  (Read 1636 times)
Offline jamesb
« on: August 10, 2013, 08:14:12 AM »
I installed my new custom airbox on my chopper (no its not a breadbox breather) I have never been so happy the bike is a lot quieter there is no noise when your flying down the road it runs better I'm kept my jets the same size I'm getting better throttle response. Everything is great. I will never use pods again I'm going to make one for my cb550 out of aluminum and see if I get the same results.
Re: I have been set free! no more pods!
« Reply #1 on: August 10, 2013, 08:21:39 AM »
Wow, that is pretty nice!  It uses stock boots?  Where did you get it?
« Reply #2 on: August 10, 2013, 08:25:47 AM »
+1
Offline 78whiteorbs
« Reply #3 on: August 10, 2013, 08:26:34 AM »
gnarly tank, lets see the rest! That is a sweet breadbox, you made that? Details :)!
Black 750K8
« Reply #4 on: August 10, 2013, 08:30:30 AM »
What is that under it?
Offline 78whiteorbs
« Reply #5 on: August 10, 2013, 08:52:48 AM »
^  +1
looks lake a fake oil tank for electrics
Offline jamesb
« Reply #6 on: August 10, 2013, 09:11:36 AM »
It is my electronics box (santee box) the breather is a custom job it's based on the old bread box breathers. it uses stock boots I'm using a heavy density foam for the filter. The only bad thing is its a little heavy my sons friend does stainless steel and aluminum welding he said he would make some up for me I'm going to have him make them out of the aluminum. I thought about just making them for the cb750's first and then make one for my 550 to see how well it works on it. The plus is you can use your stock boots. Here are more pics of the tank
Offline MotorFist
    • MotorFist
« Reply #7 on: August 10, 2013, 09:19:00 AM »
Sweet air box and wild tank! I love it
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
« Reply #8 on: August 10, 2013, 10:15:03 AM »
James, you should do a quick little write up on that bike in the project forum...it looks really sweet  :)
Offline Xnavylfr
« Reply #9 on: August 10, 2013, 10:24:02 AM »
WOW. I thought you guys HATED choppers..   That is sweet ! Old SKOLL paint job and all. Is that a AMEN frame?I saw the oil tank and motor mounts ,It IS an AMEN!
By the way guys/gals that santee box hold your ignition switch,regulator,rectifier and starter solenoid.Here's the wiring directions for the box
http://www.hondachopper.com/garage/santee_wiring_instructions/santee_wiring_instructions.pdf
Xnavylfr(CHUCK)
« Reply #10 on: August 10, 2013, 11:52:49 AM »
Nope, I don't hate choppers.  I do hate crappy looking chopped up pos's that have been senselessly hacked to look and perform worse than the stocker.  This can often be applied to cafes, brats, bobbers, street trackers, even stock restorations...and probably my bike too!  Everybody tries, most fail at the beginning.  Hopefully we learn from our mistakes and eventually end up with a great bike in the long run.
« Reply #11 on: August 10, 2013, 01:30:17 PM »
+1...choppas are cool.  Main reason I dont have one is they tend not to be good handling bikes, all roads around here are twisties.
James - that the tank your son painted, right?
Offline Xnavylfr
« Reply #12 on: August 10, 2013, 01:54:29 PM »
A chopper set up PROPERLY with telescopic FORKS or maybe a girder frontend will handle just as good as stock. I know guys with 40+ degrees of rake and girder frontend on DENVER's frames that are hard to keep up with in the twisties of NC roads. Now when you talk springer that's a different story all together.. but some of the NEW springers handle just as well as forks, seems they have learned a few things since the first ones were used.  There are some TOP notch choppers using the CB750 engines If you have any doubt look in the  CHOPPERS section here.
http://hondachopper.com/   especially look at 10,000 Samurai  AWARD WINNING!!!
Xnavylfr(CHUCK)
« Reply #13 on: August 10, 2013, 11:21:48 PM »
yep, mostly straightish roads here in Michigan....but I generally stay off most of those roads and leave my hardtail buddies waaayyy behind.  Hardtails handle fine as long as the road is smooth...not many of those in Michigan either.
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #14 on: August 11, 2013, 09:40:12 AM »
That's a neat looking Old School Cool machine. Love that tank.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline davidtime
« Reply #15 on: August 11, 2013, 10:51:39 AM »
I would love to know how the one works for the 550. I may be interested in purchasing one if the price is right.
