Author Topic: convert cb750 swing arm eye to eye?  (Read 625 times)
Offline 73hutch
« on: August 11, 2013, 10:49:16 AM »
has anyone converted a cb750 (or 550) swing arm to accept eye to eye shocks?
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Black 750K8
Re: convert cb750 swing arm eye to eye?
« Reply #1 on: August 11, 2013, 01:35:32 PM »
CycleX use to have a adapter.
« Reply #2 on: August 11, 2013, 04:48:17 PM »
If you have a set of shocks you wish to use for this mod, make sure you look at the offset at the base of the 750 shocks, if you just weld on mounts, which is quite east to do, you need to take into account this slight offset or your rear shocks may bind and wear seals out early causing leaks... ;)
