Author Topic: too lean or to rich  (Read 748 times)
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
too lean or to rich
« on: August 11, 2013, 01:01:40 PM »
With d8es plugs they get sooty and foul, d7eas now way to lean
Offline goldarrow
  • one day, i'll be an
Re: too lean or to rich
« Reply #1 on: August 11, 2013, 01:10:49 PM »
What bike? Carbs thoroughly cleaned? Try denso x24es-u?
CB550 K0
« Reply #2 on: August 11, 2013, 01:55:08 PM »
Sounds like your jetting is off
Offline bjbuchanan
« Reply #3 on: August 11, 2013, 02:56:20 PM »
I agree, one of those should be "better" atleast, not ends of the spectrum. What ranges are you testing
Offline neilc
« Reply #4 on: August 11, 2013, 03:05:57 PM »
Rebuilt carbs,with same issue am running 130 main jet needle position in middle,was running 140 main with no popping but fouling plugs,I think I,'ll go back to 140 don't want to burn up valves,does anyone have 1 140 main jet,I damaged 1 when taking it out,1971 cb750k1
Offline Xnavylfr
« Reply #5 on: August 11, 2013, 06:01:04 PM »
Are you reading these plugs after a plug chop or after a normal ride???  Plus if you use your choke to help start the bike it will tend to show as fouling the plugs. Do a plug chop and then read the plugs , if they are still sooty move your main needle clip UP 1 slot, this will allow LESS fuel to flow!! With the 140 mains.
Xnavylfr(CHUCK)
