Author Topic: Let's see your non-SOHC4 on the road  (Read 332844 times)
Re: Let's see your non-SOHC4 on the road
« Reply #2575 on: November 02, 2023, 02:37:37 PM »
Not on the road but broke down on the side of the road!
Had just fueled up on some good non-eth fuel, cruising around 30mph and went to give it the beans and no beans!!  Throttle cable broke so I just idled to a safe place to pull over.
Called a buddy, he was available and came with a trailer to rescue me within 30 min.
This is the third bike that I've experienced a broken cable. My CB550 broke one, I was able to easily adjust the idle adjustment and made it home, about a 20 min ride, no problem. I could not do it on the big Kaw, I was facing a slight incline and idling even in first gear would not have been possible to make the grade.
So, what is the life expectancy of cables?! New cables ordered...
Offline Kelly E
  • Geriatric Hooligan
« Reply #2576 on: November 02, 2023, 03:21:14 PM »
Life expectancy depends on maintenance. We use Sylglide grease on the barrels and in the cable grooves of the wheels. Along with annual cable cleaning with brake cleaner and fresh cable lube has kept them going. The only bike we have throttle cable issues is the 90' Moto Guzzi 1000 Le Man's. Inside the throttle pod is one tiny cable that is half as thick as a standard throttle cable. With the He Man return springs on the dual 40mm Del Orto carbs the tiny cable breaks regular enough to carry a spare and the tools to change it. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Online PeWe
« Reply #2577 on: November 02, 2023, 09:24:22 PM »
Throttle pull cable broke on my K6 2022 also when I intended to give all.
Stopped and fixed a higher idle so I could ride home only 3km away.
That cable had done around 35000 km. Wire snapped of ca 10 mm after the upper "plug". Maybe it bends up there.
I remember It snapped off there back in the 80's too when I noticed broken wire strands so I could replace it in time. Possible to feel and hear.
Throtte was not returning as easy as before so I should have inspected it before total snap off. My mistake.
Replaced both. I had an extra set home.
I ordered a new set direct. A must have.  Have extra for clutch  and gauges too.
Can not risk good riding days waiting for cables.
Offline newday777
« Reply #2578 on: November 03, 2023, 03:01:18 AM »
Very nice bikes. I'm partial to the Wing.
The rear(air)shocks on your GL1000 Wing seem sunk-down quite a bit 'jas67'.
They are air shocks.  I let the pressure down hoping to reduce the harshness of them.   They still hurt my back a lot when I hit dips in the road.
One of the things on "the list" over the winter is to get better shocks for it.
Suggestions?
Dump the air shocks, most companies that had them don't offer them any longer. Parts might be available to rebuild your air shocks depending on the brand they are??
Just get some good manual adjustment coil over shocks. I think Ikon and Hagon offer good shocks for your wing and will help your back in the bumps.
Ikon Basix shock will be much better than you have. Ikon is the new name for the old classic Koni shocks of the 70s and 80s made the same way after Koni went under. I put Koni shocks on my 750 back in 76 and they are still good. I stocked them for the wings and 750s when I was parts manager in the 70s. Well worth the money. Ikon are offered in 3 different levels of shocks.
https://ikonsuspensionusa.com/shop/
« Last Edit: November 03, 2023, 03:17:11 AM by newday777 »
Stu
My current rides
Prior bikes....
« Reply #2579 on: November 03, 2023, 03:54:38 AM »
Suggestions?
I got Hagons for my sidecar rig - CB750.  Very good ratio price/performance.
Also my 900 Custom originally had air shocks but I got it already with Progressive.  They work ok.
The only air shock I use is for the sidecar suspension.
Offline jas67
« Reply #2580 on: November 07, 2023, 03:29:44 AM »
Suggestions?
Quote from: davebig, post: 35382921, member: 5558
http://epmperf.com/
Contact Klaus and know what sort of ends you need he'll probably have a recommendation for springs.
https://www.ikonsuspensionusa.com/
I emailed Ikon yesterday, a Roger got back to me.    I'm going to order the 7610-1296 "Dial-a-ride".   I'm getting the steel-bodied ones, as they're more correct looking.  Also, no need to speend another $125 for aluminum bodies for this heavy bike.
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
Offline newday777
« Reply #2581 on: November 07, 2023, 04:41:21 AM »
You should be happy with the steel bodies. The Konis I have are still going well since 1976 with the steel bodies. The Ikons are made the same way.
Stu
My current rides
Prior bikes....
Online BenelliSEI
  • 1969 cb750
« Reply #2582 on: November 07, 2023, 08:15:32 AM »
Steve…. this has only happened to me once. I was close to home, so cranked the idle up to 25-2600 rpm  and actually had a pretty easy time of it. Afterwards I was thinking; would it be possible to swap in the “pull” cable and get home twisting backwards???
« Reply #2583 on: November 07, 2023, 08:34:25 AM »
Hi John...good question, I dont think so.   But depending on what broke, could the push cable be swapped in place of the pull?
I have my new cables and plan to install tomorrow, I'm guessing the end of the cable on the pull came off as there is no resistance at all. [that is what happened last time on the H2]
Online BenelliSEI
  • 1969 cb750
« Reply #2584 on: November 07, 2023, 09:34:38 AM »
Steve….. Thinking back, I also had an end break off a clutch cable too. The little barrel end dropped off at the hand lever. One of the guys I was with (riding an old Triumph)had some bicycle cable ends in his tool kit (a little barrel with a hole through it and a set screw in the end). We managed  to adjust the cable so I just got it to reach through the lever end and screw the barrel on the frayed end. Got me home and it must be in the bottom of my tool bag. Probably a handy thing to toss in!
Offline grcamna2
« Reply #2585 on: November 07, 2023, 09:44:21 AM »
+1 on that John !  Was the cable repair 'end' brass? Do you still have it ?
I think I'll look for one of those to carry in my toolkit.
Offline MoMo
  • Ride like you're invisible
« Reply #2586 on: November 07, 2023, 10:00:17 PM »
"Back in the day'  I remember soldering new barrels on the end of a cable due to minimal amount of money.  Especially in the service when I was getting 212 a month, Larry
Online BenelliSEI
  • 1969 cb750
« Reply #2587 on: November 08, 2023, 04:25:12 AM »
The ones he had were plain, plated steel. I think a good bicycle shop would have them?
Offline grcamna2
« Reply #2588 on: November 08, 2023, 07:26:57 AM »
They even have a hex-head screw;great to have 'in a pinch'.
Offline spotty
« Reply #2589 on: November 08, 2023, 12:01:11 PM »
ebay, about $15 for 30 of them
i blame Terry
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #2590 on: November 08, 2023, 02:08:01 PM »
Good you got home quickly, wouldn’t want that beauty to be out all alone.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #2591 on: November 09, 2023, 09:04:24 AM »
Back on the road!
Was checking out this local disc golf course at the local park yesterday. Thinking about trying it, any of you guys "golf"?!
« Reply #2592 on: November 09, 2023, 09:22:11 AM »
I did the disc golf thing for a while, about 20 years ago. I preferred real Frisbees to the golf discs, but I recall there was a copyright issue, so Frisbee golf turned into disc golf, with the smaller discs.
Offline jas67
« Reply #2593 on: November 17, 2023, 02:22:05 PM »
First ride with the new Ikon shocks!
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
« Reply #2594 on: November 17, 2023, 08:39:30 PM »
Jas, what's the verdict, easier on the back and more comfortable ride?
Offline jas67
« Reply #2595 on: November 18, 2023, 02:12:03 AM »
Yes,  most definitely a big improvement.
That said,  I did have too little air in the air shocks and was able to get them more tolerable, but getting them firm enough to not bottom on the big dips made it so I felt most of the little bumps a lot more.
The Ikons are fantastic.   Out of the box in the least stiff settings, very compliant and comfortable, but not walllowy, and do not bottom out on the big bumps.
« Last Edit: November 18, 2023, 02:13:49 AM by jas67 »
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #2596 on: November 18, 2023, 06:21:40 AM »
That is a beautiful GL1000
1973 CB 750 K3
Offline jas67
« Reply #2597 on: November 19, 2023, 04:35:41 PM »
Thank you.
I wanted to put the Ikons to a tougher test, so, i rode the GL1000 again today, this time on some roads that are a bit rough and bumpy in places.   I usually only ride my Ohlins-equipped bikes on these roads.
The road in the picture is one of the smoother sections of this loop.
I rode about 135 miles in total.  The Wing performed brilliantly, as did the Ikons.   This is now a bike that I'd have no trouble doing 300-400 mile days on. I just may get those racks so I can put my Hepco Becker cases on it.
I had a lot of fun today, riding it much more like a sport bike than most probably do these.   It really doesn't feel like a 600# bike when pushing it in the twisties.
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
Offline grcamna2
« Reply #2598 on: November 19, 2023, 07:52:17 PM »
Thank you.
Which model Ikon rear shocks do you have ?
Online BenelliSEI
  • 1969 cb750
« Reply #2599 on: November 20, 2023, 04:06:59 AM »
Thank you.
Have you checked the front springs for free length? My buddy Gary used Progresive  front spring set (along with the full kit for the back) and his bike was transformed.
