Author Topic: Whirring Tach  (Read 644 times)
Offline mono
  • Definitely no
Whirring Tach
« on: August 12, 2013, 10:43:28 AM »
recently developed a "whirring" sound from the tach - it's intermittent-ish, but generally becomes audible around 3K RPMs and then increases in pitch until i shift.  i removed and lubed the tach cable and speedo cable, but it still does it from time to time.  i have the cables routed as i always have, with the tightest "bend" at around a 5" radius.
just wondering if maybe it's something inside the tach itself that needs to be lubed -- i was hesitant to spray anything into the gauge itself.
Offline bjbuchanan
Re: Whirring Tach
« Reply #1 on: August 12, 2013, 03:24:32 PM »
I wouldn't spray in to the tach, you will probably just end up staining the tach face. It could very easily be a bad cable they make noise on their way out. Do you get any bouncing of the tach too? especially when you slack off the throttle
Offline mono
  • Definitely no
Re: Whirring Tach
« Reply #2 on: August 14, 2013, 08:14:29 AM »
the needle stays quite steady, but you're probably right about the cable.  it was on the bike when i got it, and for all i know is the original tach cable.
thanks for the verification to *not* spray lube into the tach, though - i'll just replace the cable and see what happens! :)
